2 members (Otto Skorzeny, 1 invisible),
92
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | I am currently in the process of rebuilding my 54 manual steering box for my 54 GMC 100. I am ordering some Penrite Steering Box lube, but I will not have it for awhile. I would like to start reassembling the steering box, but I want to pre-lube the bearings, bushings, and gears as I reassemble. Is there some type of grease or oil I could use as an assembly lube that will work well with the Penrite lube? Or should I just wait until I get the Penrite lube to reassemble my steering box.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | The lube will be more or less liquid and will therefore flow where it needs to be when you pour it in. I assembled mine dry and then added 140 weight oil purchased from a John Deere dealer...this is the same oil used in Troybuilt tiller transmissions.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Use a prelube called "Lubriplate". It's an assembly lube that dilutes after the regular lube is in, Scott | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | I have some "Lubriplate" left over from one of my engine rebuilds, so I will give it a try. Thanks for the input.
Jim
