1 members (Eisenholtz), 59 guests, and 3 robots.
Topics128,022
Posts1,055,377
Members48,422
#196518 12/28/2005 1:44 PM
I am currently in the process of rebuilding my 54 manual steering box for my 54 GMC 100. I am ordering some Penrite Steering Box lube, but I will not have it for awhile. I would like to start reassembling the steering box, but I want to pre-lube the bearings, bushings, and gears as I reassemble. Is there some type of grease or oil I could use as an assembly lube that will work well with the Penrite lube? Or should I just wait until I get the Penrite lube to reassemble my steering box.
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#196519 12/28/2005 3:50 PM
The lube will be more or less liquid and will therefore flow where it needs to be when you pour it in. I assembled mine dry and then added 140 weight oil purchased from a John Deere dealer...this is the same oil used in Troybuilt tiller transmissions.
Mike Barnes
1950 GMC 1-ton pickup
#196520 12/28/2005 3:51 PM
Use a prelube called "Lubriplate". It's an assembly lube that dilutes after the regular lube is in,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#196521 12/29/2005 1:46 AM
I have some "Lubriplate" left over from one of my engine rebuilds, so I will give it a try. Thanks for the input.
Jim
