1 members (klhansen), 119 guests, and 2 robots.
Topics128,151
Posts1,056,997
Members48,460
#195731 12/19/2005 3:59 AM
Junior Member
Junior Member
Hello;
I would like to put three point seat belts into my 1954 3100. I know some new ones are available from Chevy Duty and others, but I was wondering if something I could get from the junk yard would work (cheap). Know of anything that will sort of bolt in? Thanks in advance for your advice.
Rich
Age plays a factor in the safety of the seatbelt. I don't know if I would want to go with something used or not.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I got some take-outs from a local shop and they have worked well. Not that I have tested them in a smash-up. I only have lap belts though and I mounted them with really big washers to make sure they'd not pull through if and when...
Jim & Caroline
I got the left and right rear shoulder belts from a 199? Chevy extended-cab pickup. With a little work I got them in. Not the most professional looking but free.
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
#195736 12/21/2005 10:08 PM
Junior Member
Junior Member
Hi Guys;
Thanks for all of the good advice.
I'll get going on it.
Rich
#195737 12/21/2005 10:44 PM
I dont see why you couldn't just yank some out of a later model vehicle.. just make sure the mechinisms are in good working order, and that the latch isn't funky or worn out. (not always visable from a cosmetic inspection)
I'd go with at least the lap and sholder belt or "three point" rig.. something to keep your face from going thru the windshield after your chest is crushed by the steering wheel.. that way you can have an open casket funeral if you ever hit something head on.
