7 members (Cletus1950, Goach2, Wally / Montana, greenie-reddy, GRNHydra, Pete O, klhansen),
67
Mod | | | Forums66 Topics128,172 Posts1,057,038 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 43 Junior Member | | Junior Member Joined: Aug 2005 Posts: 43 | Hello; I would like to put three point seat belts into my 1954 3100. I know some new ones are available from Chevy Duty and others, but I was wondering if something I could get from the junk yard would work (cheap). Know of anything that will sort of bolt in? Thanks in advance for your advice. Rich | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Age plays a factor in the safety of the seatbelt. I don't know if I would want to go with something used or not. Scott | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I got some take-outs from a local shop and they have worked well. Not that I have tested them in a smash-up. I only have lap belts though and I mounted them with really big washers to make sure they'd not pull through if and when... | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | I got the left and right rear shoulder belts from a 199? Chevy extended-cab pickup. With a little work I got them in. Not the most professional looking but free. | | | | | Joined: Aug 2005 Posts: 43 Junior Member | | Junior Member Joined: Aug 2005 Posts: 43 | Hi Guys;
Thanks for all of the good advice. I'll get going on it.
Rich | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I dont see why you couldn't just yank some out of a later model vehicle.. just make sure the mechinisms are in good working order, and that the latch isn't funky or worn out. (not always visable from a cosmetic inspection)
I'd go with at least the lap and sholder belt or "three point" rig.. something to keep your face from going thru the windshield after your chest is crushed by the steering wheel.. that way you can have an open casket funeral if you ever hit something head on.
