8 members (Guitplayer, 78buckshot, Otto Skorzeny, cmayna, Cletus1950, Southerntruck, 1955 1 Series, Wayne67vert),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,156 Posts1,056,871 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | just curious to know how some of you might start your 235 WITH-OUT CHOKE CARB in the morning.
mine does not have a choke so I usually have to pump the gas and play with it but usually starts fairly easy,,, how ever,, since I installed the new replacement electronic module mine seems like it is a lot harder to start,, once started, it runs , idles good and has quit the random dieing,,
I installed new plugs tonight, they were fairly wet,, and have been in the truck for a yr or so..I am going to let it sit for a couple of mornings before starting to see if the new plugs help.
The symptoms are,, it will crank and crank and go thru this cycle and finally fire off,just feel like I am using the starter a lot more then use to, up to the point that the carb has flooded,, at any rate I will get back in a couple of days to let you know if the new plugs helped... thanks..Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Joker,
Both my 216 and 235 start pretty quickly, even after sitting for several days.
Routine I use is: Pump pedal a couple of times, pull choke slightly (if it's been a week or more) turn key on, and depress starter pedal.
216 usually fires within 2-3 cranks. 235 will fire up within same number of cranks if it's been run in the last few days.
However, if it's been sitting for a week or more, or it's real cold, it may take 15-20 cranks before she pops. Could be that I could use a new battery though.
The 250, well that's a whole nother ball of wax. It usually has to crank several times before it pops at all.
Just curious... "I am going to let it sit for a couple of mornings before starting to see if the new plugs help." Can you really let that beautiful truck sit? | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Eric, thanks,, it will be hard to let it sit with-out trying to see if it will start but that way I will get a better fill,,after I installed the plugs tonight it started right off,, so I will keep it in the garage and find out, Sunday morning,,
another question about these old foot starters,, other then running down a good battery is their any harm that you can do to them by steady cranking,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | I don't think you can hurt it as long as you don't keep cranking for a long period of time.
I'm sure someone will correct me, but I believe as long as you don't overheat it, I don't think you should have any problem. | | | | | Joined: Feb 2005 Posts: 68 Member | | Member Joined: Feb 2005 Posts: 68 | Fred with no choke a lot of times you can pump the acelerator a couple of times then let completely off the gas and crank. You can depend on it dying a couple of times but if it will run just long enough to warm the cylinders you can get over the big lean out when you first give it the gas....Ronnie | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Why don't you install a choke? Simple enough install if your carb is set up for it and I am sure it is. On cold mornings I open my choke a bit and drive the truck until my operating temp is up then I close the choke. I have tried to close it earlier but it will balk. | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | And why do you not have a choke???
Just drive em and if you dont, you are missing some fun! | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | came that way...I dont think it is that unusual, I like your signature line Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | That's not his signature line, he's not bright enough to think for himself and create his own. Seems he's only here to cause trouble since he doesn't list an e-mail address or a name or any information at all. It won't be long before he's gone if he keeps it up, Scott | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you thinking the teacher might be pickin on the old man(guess I should add g)but I sort of like it that way........but one thing Scott,,, he is lucky that we aren't his next door neighbor  Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | my 235 starts on the third crank every time. if it has set a day or two i need to pump it a bit more but it still starts in three cranks. i have a choke but have not used it in the two years that i have had the truck.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | This is just my opinion--and we all know what opinions are like. I think those old girls (engines) love a 'choke'. My 235 (46) will fire up with only about 5 turns if she has full choke! That is as long as she hasn't sat for a week and dried out the carb! After it starts, about half choke is quite enough. I can drive away for about one block and then push the choke off and the engine runs like a charm. Cheers, George | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Fellows, this is where engine HEAT comes into play. Fred, if you had engine heat to the intake, as soon as it fires, it would be warming the fuel for better evaporation into the cylinder almost immediately. The use of a choke would assist by putting alittle more fuel with not so much air. I think you'd find those wet plugs would disappear because it wouldn't take so much fuel to fire her up. While I think water heat is good, this is where I believe exhaust heat beats water heat. Just my 4 sense worth! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | The 235 in the 46 2 ton can sit for three weeks in 10 degree weather, and to start, you turn the key, stomp the gas pedal twice, then hit the stomp starter and she'll fire before it turns over twice.
Of course, you won't go anywhere till she warms up a bit.. but after 2 minutes or so of idle, you can take off in 2nd smooth as 2nd in a '46 2 ton can be.
Now the 235 in the '50 2 ton I had, seems like every time you tried to start it you had to jack with the choke.
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Got rid of the choke and throttles on my 235... new rebuilt carb and HEI ignition... Even on these cold, New England mornings I pump her a couple of times and she truns over easy. I did have the starter rebuilt by one of the best and he did a superb job.
But still having a little problem with periodic backfiring... even when warmed up. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | for what ever reason, the problem has taken place since I installed the replacement module in my mallory electronic dist, no points, condenser,before that I had no big problem with it starting, the only previous problem as mentioned was its random dieing, I did fixed this dieing problem with the new module.. tomorrow I will know if the new plugs help,I did find one of the ballast wires going to the - side of the coil not tighten good?? thanks for the response, other then the hard starting, it runs and idles great...........regards..Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | might need to set timing Fred
Bill | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | When I put in my new HEI I had a problem with her starting but then shortly dying out on me. I put in a new ignition module and have had no problems since.... But you said that you solved the dying out problem right Fred? | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | right.......this was last week I installed a new ignition module, been hard to start since but once started,,,, the rest of the time during the day while driving or restarting, it is ok, just a problem on the inital start-up.Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Just a follow up after installing new plugs Friday, went out to try it out this morn,hit the foot-pedal 3 times, stomp the starter and bingo,, she started right up and never missed a beat.. thanks to all of you that help me through this deal...........regards...Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Don't 'cha just love when that happens??!! | | |
