5 members (Hanks custodian, Southerntruck, baldeagle, Woodcmiami, J Lucas), 70 guests, and 2 robots.
Topics128,133
Posts1,056,398
Members48,441
Just realized that when I opened my package of new points, shouldn't there had been a small vial of grease to apply to the distributor shaft where the points things rubs against? I installed the new points without this grease. Better I go out and fix it?
Craig
Did the set of points have the felt wick on it or just the plastic rubbing block?
Even if the points have the felt wiper, it won't hurt to put a little high-temp grease on it. Don't overdo it, just a little goes a long way. Lubriplate lithium-base grease works well, or even disk brake rated wheel bearing grease will do in a pinch. Regular chassis grease probably isn't a good idea, as it can be thrown off the cam, and can make a big mess inside the housing.
Plastic block I believe. Tonight when I get home, I'll do a "little dab will do ya".
Trivial question time: Does anyone know what commercial the phrase "a little dab will do ya" came from?
Craig
I think that was "Brill-Cream" (spelling?)
:p
Only a Californian would guess it correctly.....
Craig
Brylcreem (this is a Real Audio file) from "77 Sunset Strip (1962)".
Tim
Tim,
I am impressed. What on earth are you also storing away?
Craig
How many of you guys actually remember Brylcream? Or even better, actually used it???
I did when I was a lot younger, and had hair.
I remember using on a regular basis ....
of course, I had hair then ... early 60's.
Helped keep that ducktail in place.
shoeless
I've still got some but I preferred Vitalis.
And for those of us who were youngsters in those days...
'Greasy Kid Stuff' was the hot item - came with a crew-cut hair brush built into the cap.
HollyWood Burr, Pineapple, Flat Top, Duck Tail, jeesh I'm feeling sooooo old. popcorn The Truth is Out There (I suspose shaving with a straight edge and the old mug doesn't count either) Jeesh maws where is my rocking chair!!
