| | | Forums66 Topics128,200 Posts1,057,405 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19416 04/05/2004 3:37 PM | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Just realized that when I opened my package of new points, shouldn't there had been a small vial of grease to apply to the distributor shaft where the points things rubs against? I installed the new points without this grease. Better I go out and fix it?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#19417 04/05/2004 4:22 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Did the set of points have the felt wick on it or just the plastic rubbing block?
#19418 04/05/2004 4:31 PM | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | Even if the points have the felt wiper, it won't hurt to put a little high-temp grease on it. Don't overdo it, just a little goes a long way. Lubriplate lithium-base grease works well, or even disk brake rated wheel bearing grease will do in a pinch. Regular chassis grease probably isn't a good idea, as it can be thrown off the cam, and can make a big mess inside the housing. Jerry
#19419 04/05/2004 8:19 PM | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Plastic block I believe. Tonight when I get home, I'll do a "little dab will do ya".
Trivial question time: Does anyone know what commercial the phrase "a little dab will do ya" came from?
#19420 04/05/2004 8:29 PM | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | I think that was "Brill-Cream" (spelling?) . :p | | |
#19421 04/05/2004 9:00 PM | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Only a Californian would guess it correctly.....
#19422 04/05/2004 9:00 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | |
#19423 04/06/2004 3:56 PM | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Tim, I am impressed. What on earth are you also storing away?
#19424 04/06/2004 8:16 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | How many of you guys actually remember Brylcream? Or even better, actually used it??? I did when I was a lot younger, and had hair. | | |
#19425 04/07/2004 12:52 AM | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | I remember using on a regular basis .... of course, I had hair then ... early 60's. Helped keep that ducktail in place.
shoeless | | |
#19426 04/07/2004 12:47 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | I've still got some but I preferred Vitalis. | | |
#19427 04/07/2004 2:57 PM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | And for those of us who were youngsters in those days...
'Greasy Kid Stuff' was the hot item - came with a crew-cut hair brush built into the cap. | | |
#19428 04/07/2004 3:26 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | HollyWood Burr, Pineapple, Flat Top, Duck Tail, jeesh I'm feeling sooooo old. popcorn The Truth is Out There (I suspose shaving with a straight edge and the old mug doesn't count either) Jeesh maws where is my rocking chair!! | | |
