9 members (JoergK., Bill Hanlon, J Lucas, Chip O, dt235sd, Gdads51, Hotrod Lincoln, 2 invisible), 75 guests, and 0 robots.
Topics128,205
Posts1,057,427
Members48,471
Just realized that when I opened my package of new points, shouldn't there had been a small vial of grease to apply to the distributor shaft where the points things rubs against? I installed the new points without this grease. Better I go out and fix it?
Craig
Did the set of points have the felt wick on it or just the plastic rubbing block?
H Online: Content
Even if the points have the felt wiper, it won't hurt to put a little high-temp grease on it. Don't overdo it, just a little goes a long way. Lubriplate lithium-base grease works well, or even disk brake rated wheel bearing grease will do in a pinch. Regular chassis grease probably isn't a good idea, as it can be thrown off the cam, and can make a big mess inside the housing.
Plastic block I believe. Tonight when I get home, I'll do a "little dab will do ya".
Trivial question time: Does anyone know what commercial the phrase "a little dab will do ya" came from?
Craig
I think that was "Brill-Cream" (spelling?)
:p
Only a Californian would guess it correctly.....
Craig
Brylcreem (this is a Real Audio file) from "77 Sunset Strip (1962)".
Tim
Tim,
I am impressed. What on earth are you also storing away?
Craig
How many of you guys actually remember Brylcream? Or even better, actually used it???
I did when I was a lot younger, and had hair.
I remember using on a regular basis ....
of course, I had hair then ... early 60's.
Helped keep that ducktail in place.
shoeless
I've still got some but I preferred Vitalis.
And for those of us who were youngsters in those days...
'Greasy Kid Stuff' was the hot item - came with a crew-cut hair brush built into the cap.
HollyWood Burr, Pineapple, Flat Top, Duck Tail, jeesh I'm feeling sooooo old. popcorn The Truth is Out There (I suspose shaving with a straight edge and the old mug doesn't count either) Jeesh maws where is my rocking chair!!
