1 members (69Cuda), 73 guests, and 4 robots.
Topics128,096
Posts1,056,487
Members48,444
#190402 09/29/2005 1:14 AM
Z
Z Offline
the carb on my 235 has a metal 1/2" spacer under it.is there susposed to be a gasket under it?mine was metal to metal.
#190403 09/29/2005 1:41 AM
That doesn't sound right. Metal would conduct heat to the carb, just what you don't want. Jim Carter and other dealers sell the correct high temp plastic insulator.
Steve
See my 1940 Canadian GMC:
http://community.webshots.com/user/ndnchf
#190404 09/30/2005 1:24 AM
Z
Z Offline
i know its metal because i cleaned it with a wire wheel.its got two slots in it that line up with the carb gasket.
#190405 09/30/2005 1:33 AM
ODSS Lawman
ODSS Lawman
I agree with Steve, you need someting other than metal between the carb and the manifold. But to answer your first question, yes there needs to be a gasket between them.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
#190406 09/30/2005 1:38 AM
This was discussed recently. Search the forums for metal and carb spacer.
The advice was if you have a metal spacer you need two gaskets.
Intake, gasket, spacer, gasket, carb.
Bill Schickling
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
#190407 09/30/2005 1:48 AM
I got Jim Carter's new catalog and in the back he has a help section that has illustrations of engine assemblies. It shows manifold, gasket, spacer, gasket and carb. The pic looks like its from an assembly manual. BTW, my spacer is made out of some kind of dense plastic. I've never seen a metal one. They are supposed to insulate from the heat of the manifold. Metal seems counter productive.
