4 members (2-Ton, Bill Hanlon, 2 invisible),
90
Mod | | | Forums66 Topics128,142 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | the carb on my 235 has a metal 1/2" spacer under it.is there susposed to be a gasket under it?mine was metal to metal. | | | | | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | That doesn't sound right. Metal would conduct heat to the carb, just what you don't want. Jim Carter and other dealers sell the correct high temp plastic insulator. Steve | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i know its metal because i cleaned it with a wire wheel.its got two slots in it that line up with the carb gasket. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | I agree with Steve, you need someting other than metal between the carb and the manifold. But to answer your first question, yes there needs to be a gasket between them.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | This was discussed recently. Search the forums for metal and carb spacer.
The advice was if you have a metal spacer you need two gaskets.
Intake, gasket, spacer, gasket, carb.
Bill Schickling | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I got Jim Carter's new catalog and in the back he has a help section that has illustrations of engine assemblies. It shows manifold, gasket, spacer, gasket and carb. The pic looks like its from an assembly manual. BTW, my spacer is made out of some kind of dense plastic. I've never seen a metal one. They are supposed to insulate from the heat of the manifold. Metal seems counter productive. | | |
