| | | Forums66 Topics128,090 Posts1,056,014 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 22 Apprentice | | Apprentice Joined: Jul 2003 Posts: 22 | My gas guage would not only stay on empty when full, but actually go in the opposite direction! I pulled the sending unit and all looks ok except instead of a brass float on the end it has cork! It looks factory as there is a washer with a very neat little knurl on the shaft to hold it on. My guess is that the cork has gotten super saturated over the last half century and stayed sunk on the bottom like a Russian submarine. I ordered a brass float from JC but it has no holes through the center and I think it accepts a ring type attachment. Now I'm just thinking about putting new cork on it. Any ideas what might work? Could I drill the brass float and JB Weld the rod to it? Does JB Weld or any other epoxy dissolve in gasoline?
Cap'n Mark | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | What about dipping the whole end of the sender and cork in that plastic covering for pliers handles,then wiping off the excess lightly,to be sure it's still covered but still light enough to float properly? Speed | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | By the time you get this fixed your prolly gonna wish ya just bought a whole new sender. I think they are around $40. You may get a cork float on there and it still dosen't work. You might want to check it with an ohmeter and see if it really works first. Good luck. | | |
