0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
Apprentice
Apprentice
My gas guage would not only stay on empty when full, but actually go in the opposite direction! I pulled the sending unit and all looks ok except instead of a brass float on the end it has cork! It looks factory as there is a washer with a very neat little knurl on the shaft to hold it on. My guess is that the cork has gotten super saturated over the last half century and stayed sunk on the bottom like a Russian submarine. I ordered a brass float from JC but it has no holes through the center and I think it accepts a ring type attachment. Now I'm just thinking about putting new cork on it. Any ideas what might work? Could I drill the brass float and JB Weld the rod to it? Does JB Weld or any other epoxy dissolve in gasoline?
Cap'n Mark
What about dipping the whole end of the sender and cork in that plastic covering for pliers handles,then wiping off the excess lightly,to be sure it's still covered but still light enough to float properly?
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
By the time you get this fixed your prolly gonna wish ya just bought a whole new sender. I think they are around $40. You may get a cork float on there and it still dosen't work. You might want to check it with an ohmeter and see if it really works first. Good luck.
