7 members (Otto Skorzeny, J Lucas, dt235sd, Cosmo, jeffreyguy, Charles in CA, LAROKE), 132 guests, and 6 robots.
Topics128,107
Posts1,056,221
Members48,436
Junior Member
Junior Member
Hi,
I'm a proud new owner of a '49 5 window 3100/ '54 hybrid (the box is a '54). I am learning so much so quickly - like how to be a mechanic. Please don't laugh to loudly but there are a lot of terms used in the stovebolt world that I am unfamilier with. Could someone kindly explain what a 10 bolt axle is and what the difference between that and others? Also, what is a pumpkin?
Dumb, I know. But if you never ask.....
A pumpkin is an orange gourd generally asociated with fall. smile
Actually a pumpkin is the slang term used to describe the rear axl differential.. cause its big and kinda round.. like a pumpkin.
I never was 100% sure what the "bolt" rating on rear ends meant.. I always kinda figured it meant how many bolts were holding the cover on.
Refer to the following crude illustration:
[img]http://www.oldtruckstuff.com/punkin.gif[/img]
Fumblin is right. "10 bolt" is a descriptive name of a GM axle that has 10 bolts holding the differential cover.
It's NOT a rating. A GM 12 bolt, for instance, isn't stronger than a 10 bolt by virtue of the 2 extra bolts -- except if you're trying to rip the differential cover off with a crowbar smile
And Fumblin, I hope you're not considering a career in graphic design!
Brian
A pumpkin is actually the removable differential assembly on front loaded rear ends. It includes the ring and pinion, carrier assembly including the differential gears(spiders etc.) and the front cover. Techically the rear access only rear ends don't have pumpkins.
Baldy
Junior Member
Junior Member
Thanks everyone! You guys (& gals) are all so helpful. It is an honor to become a member of the Stovebolt community.
Aloha,
Rich
Geeze, Rich. Keep saying things like that and these guys are going to be impossible to live with :p
Welcome to the 'bolt. Are you aware that our fearless leaders, Peg & John Milliman, lived in the Aloha state for several years?
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
On 10 and 12 bolt Chevy rearends, that actually refers to the number of bolts that hold the ring gear to the carrier. Yes a 10 bolt and a 12 bolt Chevy do have 10 and 12 bolts holding the cover on.
Ron Thompson
51 Chevy 1/2 ton
36 F@rd coupe
65 Riviera
so then wouldn't a 12 bolt actually be stronger than a 10 bolt if that describes the number of bolts holding the rings gear to the carrier?
i always thought it did anyway. when you see 69 camaros for sale, the 12 bolts are the SS and 10 bolts are the SS wannabes.
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
Rich,
Aloha! Just checking in real quick at the end of the day!
Yes, we were in Kaneohe Bay from 7/95 to 6/98. AAMOF, The Stovebolt Page was "birthed" in Base Housing at MCB K-Bay.
Still have many friend there.
Welcome to the site. We've got great folks here.
Peg
~ One of many.
Junior Member
Junior Member
What a great discussion started from such a seemingly silly question. I'm glad I asked as I am now that much better informed. Thanks to all.
Peg, nice to hear from a former Windward neighbor. As you may well know, vintage trucks on our O'ahu roads are a fairly rare site. It's great to see all the smiles it brings when I drive my '49 around Kahalu'u and Kaneohe - not to mention the grin on my own face!
And thanks for the nice welcome.
A Hui Hou,
Rich
Greetings, Rich, and welcome- from another Rich!!
You'll learn a lot here. I know I have!
And by the way, Fumblin, I kind of like your art work! This is the second thread we've seen it on-Maybe you'll have to produce an illustrated handbook for us dummies! grin
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
On GM rear axles there is a relationship between the number of bolts holding the cover on and the strength of the axle.
But the number of bolts holding the cover on is not what gives it more strength.
The strength comes from the increased size of the ring gear and the related parts. More bolts are used to hold the ring gear in place which probably does contribute to the strength. You commonly hear Ford axles called eight-inch or nine-inch and that measure relates to the size of the ring gear.
On the GM 10-bolt axles there are several size dimensions that I've seen, so its a little more complicated to know exactly what you have. A 12-bolt is generally stronger than a 10-bolt and the 14-bolt is stronger yet.
Rich,
Ya wanna know sometin dat was pretty strange ya? We had a big old black Dodge while we were there. On the island, man, Dodgezilla looked even bigga with all those little cars -- especially the old VW's. Loved those old VW's!
Aloha,
Peg
~ One of many.
what can you tell us about a 9 inch Ford?
Redryder pix
My Hotrod
Quote
They were original equipment on many Fords starting in the 50's and continuing into the 70's or maybe 80's, and are now hard to find and becoming somewhat expensive.
They are an easy choice for the same reasons a small block Chevy is popular; good design and lots of aftermarket support.
I have GM axles under everything except my wife's Subaru.
What kind of Subaru do you have Steve? I work for a Nissan/Subaru dealer here in Cedar Rapids. Do you like it?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
