8 members (mick53, Lostbuthaulinass, carbking, Southerntruck, Otto Skorzeny, 1955 1 Series, 52Carl, cmayna),
154
0
Mod | | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | what's the difference between AND what do they stand for ???????? SB SBC BB when it comes to trucks, or motors ???
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Typically they stand for: SB - Small Block SBC - Small Block Chevy BB - Big Block (BBC would be Big block Chevy)
Again typcially the small block designation pertains to engines with standard cubic inch displacement below 400 and the big block designation is for 400 and above although there are a couple of minor exceptions such as the Chevy 402 which can be either a SB or a BB I believe depending on the year and the chevy 396 which is considered a BB.
Other manufacturers such as Mopar and Ford fall in the same ranges, again with some minor exceptions. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Thanks Houston that clears it up
| | | | | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | My understading on the 400/402 deal is that the "real" 400 is a smallblock (I have 3 of them) and that the bigblock 396 was "labeled" as a 400 in some applications when the 400 motor was defined as GM's largest powerplant.
The 402 came about as a machining error at the assembly plant necessitated the re-boring of many blocks to .030 over, thus creating a 402....but many of them were sold as wither 396 or 400s. What a mess.
One other use I've seen to differentiate is that SB seems to be used occasionally to represent StoveBolt, SBC for smallblock and BBC for big block.
Sorry, Caroline...if it was clear before, I'm afraid that I just muddied the waters. | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | Not to muddle things up more, but what about the 348 and 366? They are big blocks too, right?
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | Fab,
If I'm thinking about the same thing that you are -- the big engine available in the late 50s, early 60s, I think THAT engine was neither fish nor fowl. Not an SBC, but not a BBC either. The internal pics I've seen of that certainly don't look like the BBCs that I remember.
Brian | | | | | | Anonymous Unregistered | | Anonymous Unregistered | To my understanding the "small block" terminology began with the Chevy 265 V8. | | | | | Joined: Aug 2003 Posts: 31 Junior Member | | Junior Member Joined: Aug 2003 Posts: 31 | The term 'small block' refers to the actual outside dimensions of the block not the cubic inch displacement. The chevy 350 smallblock has the same outside dimensions as the 327 or even the 400 small block. There are many different CID's when it comes to the Chevy smallblock. To many to list. The 'big block' is built different. Much bigger outside dimensions even though it can still come in a 350 CID. The smallblock is smaller in overall dimensions and weight. This is good because less weight and size with the same CID. Translated means more power to weight ratio. And of course, tons of performance parts--Cheap!
I feel like I'm diagonally parked in a parallel universe.
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I believe the 348/409 was called a WBC for Wide Block, but of course W in a F**d means Windsor. | | | | | Joined: Mar 2005 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 59 | the 348/409 is called a "W" block because of the shape of the valve covers
there are a select few parts that are interchangeble with the small block and other parts that are common with the big block but very few
rh | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | When I worked at the Chev. assembly plant in Van Nuys in 1958 the engine was referred to as the W-3 because of the shape of the valve covers. | | |
