| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | The oldest son and I were working on stripping some parts off of the donor Blazer yesterday.
We also have a donor Chevy van. It is a IRWIPI 12 years ago - freebie that I figured we might get something useful out of so we towed it home. I was curious as to whether or not it would actually run, so I hooked up a set of jumper cables, poured a little gas in the carb and cranked it over.
Wouldn't you know it, it sparked to life. It sat there running on 12 year old gasoline for about fifteen minutes, then I threw it into reverse and it actually moved, so I put it in drive and it moves forward as well. I am totally amazed!... I didn't even lube the cylinders first!
We might end up using the tranny for the 57 Panel, and the engine will probably end up in the swap meet eventually. (its a six cylinder...250?...I think) | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you caught her in just the right mood,,,,,,,,,,,Fred
just drive em,,,,,,,,,,,,,,,,,,,,,,,,,, Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Guess you're right, Fred. I don't usually get that lucky  | | | | | Joined: Jun 2005 Posts: 3 Junior Member | | Junior Member Joined: Jun 2005 Posts: 3 | Awesome, these old Chevy's are just wanting to show that they just keep going. It was just waiting to show you what she could do.
Owen Miller
| | | | | Joined: Jul 2004 Posts: 2,986 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,986 | You're probably lucky you had 12 year old gas in it. This modern crap goes bad in about 6 months! | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Where can I get some of that good six month stuff? Seems like out here it sours if I don't drive my truck for two weeks... | | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Speed, I might have a couple gallons of the twelve year stuff I could sell you... LOL
If the new stuff is $2.25/Gal. then the aged stuff should be worth $5.50... Right??? | | | | | Joined: Apr 2005 Posts: 11 Junior Member | | Junior Member Joined: Apr 2005 Posts: 11 | I recently had the same experience with a 1959 Dodge D100. I got it started on the 15+ year old gas. It ran but it was a little lean. I cleaned the carb and it ran better but still lean. I think that the gas had lost most of its volatility. It since ran out of gas and I havent had time to pour fresh stuff in and try again. I do know that todays fuels go varnishy in a few months. I was amazed at the old gas. | | |
