0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#181178 11/16/2004 4:01 AM
Hi,
Finally got my 55 1st. up and running smile . The problem is looking at it dead on it tilts to the left, not huge but enough to notice. The car sat for almost a year on a driveway that also is on a slight hill. And it seems to me that the '55 got comfy leaning that way for so long. I am also sure it did not tilt before it was parked. I asked a few people and they have suggested driving it and it will eventually settle, which sounds way too easy. Any help would grand!
Thanks in advance
#181179 11/16/2004 5:17 AM
Look the springs over real carefull. Broken leafs are not unusual. Look for visible breaks or cracks in a leaf, or places where the curve of the spring seems to reverse slightly.
This past weekend I removed the front springs from my '55 1st because 4 leafs are broken on the right side. Next weekend I hope to get it back together and start driving it again!
#181180 11/16/2004 5:18 AM
My truck tilts. In fact it was my first question on this forum too. For a while they called me leaning Tony.
At first I thought it was the front springs so I changed those. But really it is the cab mounts that is missing some rubber. On some this can be rusted out as well. Hopefully yours is just the missing rubber.
54 3100 with 235
62 flatbed dump C60 with 261
#181181 11/16/2004 7:29 PM
Thanks Steve and Tony for the info,
I'll take a peek at it and see what I can figure out. I'm hoping for the cab mounts. Odd that we both had the same first posts. Oh well, I'll keep you posted on my progress or lack of.
Thanks again,
PJDEE
#181182 11/16/2004 11:41 PM
pjdee, i have the same problem and time won't correct it on its own. my floor is rotted down by the kick panel and has come a way from the floor which supports the floor and keeps it from the truck from settleing over the supports. hope this helps. btw you can get new floor panels from numerous sources. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#181183 11/17/2004 1:17 AM
Just park it leaning the other way for a while,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#181184 11/29/2004 3:57 PM
My 54 0ne ton leans to the left a little bit. Cant find any reason. The cab mounts, springs,etc all look good. I am not going to worry about it.It will just look like a fat man is driving it.That will be true anyway.
I like old trucks
