3 members (fonz8261, 5cameo8, Barry Martak), 114 guests, and 2 robots.
Topics128,089
Posts1,056,418
Members48,443
#176637 11/12/2004 3:48 AM
If you dont have a fire extingwisher with in close reach in your garage now, go get one ... frown
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
I hope you are not speaking from experience?
54 3100 with 235
62 flatbed dump C60 with 261
A very good suggestion. Let me add to it. Check it now and then. I haven't thought about mine for a while. It's sitting there right handy but does it have dirt daubers in the nozzle? Has it bled down? I'll check tommorrow. Thanks for the reminder.
Priming a truck that had run out of gas.A back fire out the carb lit a pretty good blaze.Itryed beating it out with my hat but that just seemed to spread it.A month ago i bought two fire extinguishers at an auction and hung them at each end of the garage.At first i forgot i had them.I wont be without a gain.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
I
I Offline
My brother set his head on fire doin that.
gotta be extremely careful.
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
I was headed camping this past summer on a windy day. I was on a fire road in far northern CA. I was driving my CJ 5 and pulling an old military trailer. My buddy put his chairs on top of a spare battery I had in the trailer. it arced across the terminals and caught fire. By the time I got to it with the extinguisher a 1 gallon can of colman fuel had a hole burnt in it and was shooting flames many feet into the air. Without the extinguisher You would have seen me on the news.
I bought a new extinguisher as soon as I got home.
Brian D
From the sound of things--all you guys need extinguishers--wives shouldn't let you go around equipment w/o asbestos suits. Sweet heysous you boys are dangerous-- grin grin grin
Buzz'n Half Dozen
I tried to put out one of those with a hat once, I actually had to use my jacket. Threw it over the carb and that did the trick. Sure miss that jacket...
54 3100 with 235
Socket Breaker
Socket Breaker
I want to get a extinguisher for my '65 c10 ... ?I have no idea where to go look for one tho'... nor where to mount it. It's kinda cramped in that regualr cab... hehee..
-W
Got mine! grin
Woogeroo, Most Heavy duty truck dealerships sell them. they are required on heavy trucks by the DOT. They will be the correct rating (ABC) for automotive uses and include mounting bracket. Get creative on mounting location. if you mount it outside cover to protect from weather. Be sure where ever you mount it that its easily accessable and you can reach the clasp to turn it loose from mounting bracket
