6 members (WICruiser, dt235sd, GMCJammer51, Phak1, Goach2, Southerntruck), 52 guests, and 0 robots.
Topics128,196
Posts1,057,395
Members48,471
Socket Breaker
Socket Breaker
Hiyas.
I have seen the various aftermarket 3 point seat belts for bench seats... but I am curious about mounting them up in a AD truck that has the corner windows... the '5 window cab' as some call it.
The truck in question:
http://hardin.home.mindspring.com/1953/1953.html
Has it been done? Any of you done it? have pictures? seen a website with pictures?
Or do folks just use the lap belts in this situation?
Thanks.
-W
p.s. that is my dad's truck. He's had his longer than I've had my '65, but mine drives around. hehe.
Woog,
there have been threads on this, but I haven't fully taken them in. However there is a hole up high in the post, maybe partially hidden by the windlace. That hole is accessable from inside the post if the head liner is off. This is because the top of the inside of the post is open at the top. I assume that that is where the reinforcement plate is placed.
1951 1 Ton Completed
i saw it in one of my magazines they weld a plate just back of the door frame. thats why i want to go to seats that have a built on seat belt ( buick lesabre about 2002-2005. RON
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Woog-
Do a search and you'll find lots of insight and archived photos. For safety sake in a truck with latches that do not keep the doors closed in a crash, this is an important feature. Visit Juliano's or Gem Street rods for components. Juliano's sells a backing plate you can weld in for the strongest pillar attachment.
In my '54 GMC, there is actually an existing hole for the D ring on the pillar (as noted, hidden by the rubber windlace). I will widen this to accept the D bolt and back it to avoid pull-out during a crash. The seat is out as of last weekend and I am putting these in as soon as possible (if I could find the time)!
Mine doesn't have the corner windows, but my experience may help. Got a set of belts (Dodge truck, actually. They fit better than Chev behind the door pillar.) Made a mount plate like the original. For the top corner, welded BIG fender washers to the mounting nuts (Grade 8 to match the original collared bolts). Drilled 4 holes: 1 for the bolt (9/16 if I remember), and three 1/4 spaced around the bolt hole, close enough to be covered by said WASHER. Taped the nut/washer to the open end of a combo wrench (tied a string to the box end in case I dropped it) and lowered the nut/washer down behind the inner skin near the pillar. Used a short bolt to hold everything from the inside and plug welded the WASHER in place. To keep the seat belt bolt from backing out, use thread locker and/or SLIGHTLY deform the nut prior to welding to the washer (thread a bolt in about 1/2 way, put the side of the nut on an anvil and strike the side of the open end with a hammer to oval the bolt exit side. SLIGHTLY.)
If my method is unsafe, I'm sure someone will chime in. I'll appreciate it as much as you. The belts are firmly anchored and easy to use.
When I bought my 5 window it had shoulder harnesses installed. If you give me an email address I will send what photos I can of the finished install.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Here are some search results with links within:
3 pt belts
Mongo\'s reply with links
Andover Instructions with links
Vintage Trucks link
This Stovebolt thread had really good pics, but I am not sure the links still work.
Good luck and keep us posted!
Socket Breaker
Socket Breaker
51phatboy - thanks for the links and threads.
Thanks everyone else also!
-W
