4 members (HelmutVonSchet, walter74, jay d, Rich'sToys), 95 guests, and 2 robots.
Topics128,049
Posts1,055,678
#164107 03/14/2006 6:24 AM
I have taken the gas tank out of my 66. I now have a desire to put in another seat that will provide an armrest. I wonder if a bench seat from a 92 or 97 Silverado will fit. How much modification would it take to add mount to the floor?
#164108 03/14/2006 10:49 PM
a seat from a 2000 or newer buick lesabre should fit. you get the armrest and leather or cloth. around here they run about 150.00 complete. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#164109 03/14/2006 11:37 PM
If u go with later model chevy or gmc truck seats they will bolt flat on the floor. The yucon, tahoe or denali also would work really well. Best part is they have the seat belts built in.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#164110 03/15/2006 5:43 AM
I guess the thing to do is go the junk yard and see what options I have and then measure and modify the cab floor as I need to.
#164111 03/15/2006 11:11 PM
Has anyone ever put S10 seats/seatbelts into an AD truck?
#164112 03/18/2006 8:51 PM
I think most of the s-10 seats are too small (not wide enough from door to door).
I'd love to have a head rest.
What I'm planning on doing with my seat this weekend is to find just a backrest that is not as thick as the one that came with the truck. Then I'll use the material from the upholserty kit to cover to replacement so it'll match the bottom and give me some breathing room infront of the steering wheel.
#164113 03/27/2006 9:10 PM
T-Bird seats are kinda nice.
#164114 03/28/2006 12:06 AM
If you put in seats that have the seat belts built in, does the floor of the cab or some other sheet metal need to be reinforced? Since the seats are only attached at the floor, the floor metal seems a bit dinky to hold the seats down in the event of a collision.
#164115 04/01/2006 4:37 AM
Good question?? I was kinda thinking the same thing and hoping to work the topic towards that.
Soooo? can somebody tell what you'v done?
#164116 04/03/2006 2:14 AM
have you ever looked to see what is holding the seats in a new car.... they are pretty dinky too.
at most just a stamped sheetmetal brace.
it's not old it's "aged to perfection"
http://brent5631.myphotoalbum.com/
#164117 04/03/2006 3:29 AM
I used 2000 buick seats( leather, electric and heated) in my 50. When I bolted them to the floor, I made 1/4 in. plates for underneath the floor for added support.
#164118 04/05/2006 1:59 AM
Wilbur, did those go directly onto the floor or on the "riser" (not sure what you call it) that the stock seat sits on?
#164119 04/05/2006 1:27 PM
For the buick seat I had to make risers. I downloaded some pics. have a look.
#164120 04/07/2006 12:25 AM
i am sorry but i couldn't find your pix. ron
2017 Buick Encore
See more pix
#164121 04/07/2006 12:31 AM
Wilbur - as Ron sez, your link to yahoo isn't to your album, it's to the log in page! you need to go to your public album and copy that address, not the one you use to edit your album
#164122 05/05/2006 11:34 PM
Junior Member
Junior Member
Any Ideas on a replacement seat for a 1938 Chevy Truck? ie: s-10
#164123 05/06/2006 12:30 AM
Welcome to the bolt danielinca,
The s-10 is a good place to start but you may find the seat will be to low. Take a tape measure to the scrap yard with you and start measuring different seats.
Goodluck and welcome you"ll find this site very useful.
#164124 05/06/2006 1:40 PM
I think I fixed my picture problem.
#164125 05/10/2006 7:40 PM
William, I can't remember if I asked you this, but do the Buick seats fit with the gas tank remaining in the cab?
#164126 05/11/2006 12:18 AM
I don't have the tank in the cab, it's out back. But I don't see any problem with them fitting with the tank in the cab. Their seems to be plenty of room behind my seat.
#164127 05/11/2006 11:08 PM
OK thanks. I'll put in my order.
#164128 05/30/2006 4:49 AM
Quote
I picked up a bench seat with a fold down arm rest from a 95 Silverado. Its as close to a bolt in as you'll find for your 66. Some of the newer trucks have integral seat belts which would have been nice but for $30.00 I can't complain.
Dave
66 GMC- father /son project with the "GMC KID"
36 Chevy PU- 4x4 lifetime project
64 Skylark- wife says its hers
#164129 05/30/2006 6:56 AM
Wilber what kind of gas tank do you have in your truck i need to get one for my 50 chevy
#164130 05/30/2006 1:21 PM
The tank is from a 70 mustang. I made the frame from 1in sq tubing then notched and boxed the rear crossmember to get the tank up into the frame higher. I then cut the top off the old filler neck from the truck and welded it to the tank to be just below the floor.
wilbur
#164131 06/04/2006 2:40 AM
Junior Member
Junior Member
Does anyone know what seat is the best for a 52 chevy 1/2 ton with the least amount of fabrication.
Smoke Em if You Got Em
RYAN
#164132 06/07/2006 2:28 AM
Junior Member
Junior Member
Similar to Crib66. I have a 63. Any experiances with new benches with fold down armrests?
#164133 06/07/2006 4:48 AM
Quote
I had much the same question. I'm in the middle of repairing rust on the floor and am replacing the rear cab mounts on our 66. The seat belt nuts are welded to the cab mounts so I thought maybe a larger heavier guage metal plate underneath would be a good idea for safety. The existing set up is only the floor sheet metal and then the thin metal on the floor support.Each are probably only 18 guage metal. I called someone I know who is an expert in vehicle standards and safety ( he's also restoring an old "Harvard" airplane, a "Texan" I think in the USA). He claims that you would need about 5000lbs of force to rip that seat belt nut out of those 2 layers of sheet metal. He said that if you're in a severe enough collision where there is that much force, seat belts won't matter to you anymore. If I was installing a seat with integral belts I would probably run a couple of 16 guage or so straps under the floor where the seat bolts are, but more for my own piece of mind than anything else.
Back in my towing days I was called to a lot of ugly collisions but I don't recall ever seeing a seat or seat belt bolt ripped out of a floor.
One thing I would do is use Grade 8 high quality bolts to attach the seat. The bolts you've got left over from assembling your kid's swing set wouldn't be a good idea..
Dave
#164134 06/07/2006 10:19 PM
I don't know. 5,000 lbs sounds like a lot of force, but when you are trying to dissipate the force of your weight moving 40 mph or so to zero in a fraction of a second, you may get up there pretty quickly. If you're just talking about a lap belt, its probably not a problem. Adding a 2.5' lever (the seat back) as a prybar amplifies the force. One guy I was talking to recommended only the lap belt. He said the B pillar won't hold much anyway. However I didn't see a sliderule or pocket protector on his shirt.
Moderated by  ndkid275, Phak1
