8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | Hello all; just got my one piece headliner for my '41. It says to use water and amonia to form, but no instructions were given. What dilution rate do I use? Do you get the piece wet or damp? Any help is welcome thnaks  1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I've read someplace its a 50/50 mix, but not 100% sure. You only want to slightly dampen the backside. You get it to wet and you'll have pieces of cardboard in your hand. Don't know about a '41, but on my '51 it took an extra set of hands. Cecil.............. | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | I've also read on other posts that the strength of the ammonia will affect the dilution you need. Many household ammonias are already diluted - check your bottle before starting. Try putting it in a spray bottle and give a gentle mist on the back to prevent over-wetting the headliner.
For my AD, the headliner arrived rolled, so I laid it out on a large table and sat heavy books on it for several days before installing it. That worked really well. As Cecil said, my project (54) also took a helper to get it in.
Good luck. | | |
