4 members (Hotrod Lincoln, 55shaker, rfs56trk, Wally / Montana), 99 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#163618 10/21/2005 4:50 AM
Dv8
Offline
I would like to replace the bucket seats from my 54 that were added by last owner. I would like a bench seat in leather. Can anybody point me in a direction of a donor vehicle. I've heard mini-van second seats, but would like an idea of what vehicles to look for at the treasure yard.
I'm not driving fast...
I'm flying low
54 chev 3100 5 window
65 corvair powered Manx Clone
93 Trans Am 6spd LT1
#163619 10/21/2005 1:41 PM
Here are some previous discussions where this topic was the subject. Maybe they'll help.
Good luck!
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=20;t=000262#000002
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=000516#000000
~ Kimberly
My '54 ... and my '63 and a '59 F100
#163620 10/21/2005 3:01 PM
dv8, seats from a 2000 or newer buick lesabre will work and they have built in shoulder belts and nice console. have been quoted 125.00 complete and that is less than a three point seatbelt conversion. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#163621 10/21/2005 6:49 PM
Ron,
If a person were to put the seats you mentioned into their truck, do you have to chop out the existing sheetmetal that holds the old seat frame?
Stuart.
#163622 10/21/2005 11:30 PM
dv8, i have not done it yet buuuuuut i would think that would be the case. you would have to build a riser to span the dip in the floor. i was told by a fellow bolter in a previous post that there are spot welds and they have to be carefuly drilled out. it does not look to hard. i have fornd acouple of seats locally but they were either cloth or damage was to the driverside door and intruded on the seats, i am still looking. btw there is a special tool from eastwood and other places to drill out the spot welds with little damage to the floor. go to www.autonetworkinc.com and click on parts and go to 2000 buick lesabre for pictures. ron
2017 Buick Encore
See more pix
#163623 10/28/2005 12:07 PM
Dv8
Offline
Wow Thanks We b old That is pretty much exactly what I was looking for. What do you mean I would need to remove spot welds??? Or a better question would be why??
I'm flying low
#163624 10/28/2005 1:45 PM
the spot welds hold the seat base in the old truck . you would have to remove it to install the new seat i don't think you could install the seat on top of the old base. ron
2017 Buick Encore
See more pix
#163625 11/01/2005 6:56 AM
Junior Member
Junior Member
Don't drill out the spots welds, only to have to fill them. Use an angle grinder to take out the seat base. About 30-mins to smooth.
Today,I know next to nothing. Tomorrow's a different story.
#163626 11/01/2005 5:13 PM
A spot weld cutter from the top will just leave little spots to smooth out.
1954 GMC De Luxe COE
#163627 11/02/2005 2:29 AM
I used up 2 spotweld cutters before I got the left side cowl off my '54 GMC. Then I thought about a 3/8" drill I bought from NAPA for another job. I don't know what the drill was designed for but the way it is sharpened it has a point in the center to put in a pilot hole and cutting points on the outside diameter. It worked great on spotwelds.
Moderated by  ndkid275, Phak1
