8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, msmall),
122
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 7 New Guy | | New Guy Joined: Feb 2005 Posts: 7 | I would like to replace the bucket seats from my 54 that were added by last owner. I would like a bench seat in leather. Can anybody point me in a direction of a donor vehicle. I've heard mini-van second seats, but would like an idea of what vehicles to look for at the treasure yard.
I'm not driving fast... I'm flying low 54 chev 3100 5 window 65 corvair powered Manx Clone 93 Trans Am 6spd LT1
| | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Here are some previous discussions where this topic was the subject. Maybe they'll help.
Good luck!
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=20;t=000262#000002
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=000516#000000 | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | dv8, seats from a 2000 or newer buick lesabre will work and they have built in shoulder belts and nice console. have been quoted 125.00 complete and that is less than a three point seatbelt conversion. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Ron,
If a person were to put the seats you mentioned into their truck, do you have to chop out the existing sheetmetal that holds the old seat frame?
Stuart. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | dv8, i have not done it yet buuuuuut i would think that would be the case. you would have to build a riser to span the dip in the floor. i was told by a fellow bolter in a previous post that there are spot welds and they have to be carefuly drilled out. it does not look to hard. i have fornd acouple of seats locally but they were either cloth or damage was to the driverside door and intruded on the seats, i am still looking. btw there is a special tool from eastwood and other places to drill out the spot welds with little damage to the floor. go to www.autonetworkinc.com and click on parts and go to 2000 buick lesabre for pictures. ron
| | | | | Joined: Feb 2005 Posts: 7 New Guy | | New Guy Joined: Feb 2005 Posts: 7 | Wow Thanks We b old That is pretty much exactly what I was looking for. What do you mean I would need to remove spot welds??? Or a better question would be why??
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | the spot welds hold the seat base in the old truck . you would have to remove it to install the new seat i don't think you could install the seat on top of the old base. ron
| | | | | Joined: Nov 2004 Posts: 1 Junior Member | | Junior Member Joined: Nov 2004 Posts: 1 | Don't drill out the spots welds, only to have to fill them. Use an angle grinder to take out the seat base. About 30-mins to smooth.
Today,I know next to nothing. Tomorrow's a different story.
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | A spot weld cutter from the top will just leave little spots to smooth out. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I used up 2 spotweld cutters before I got the left side cowl off my '54 GMC. Then I thought about a 3/8" drill I bought from NAPA for another job. I don't know what the drill was designed for but the way it is sharpened it has a point in the center to put in a pilot hole and cutting points on the outside diameter. It worked great on spotwelds. | | |
