Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Jon G, Dennys28, Uncles51, texas46), 113 guests, and 1 robot.
Topics128,279
Posts1,058,593
Members48,492
I am unable to find any info on this repair kit. It came from Barry Week's auction.
Brendan
1940 Chevrolet 1/2-Ton Pickup
Restoring Dad's old truck
1 Offline
Water pump repair kit. Someone eill know what for and what years.
Says Chevy '41 Up right on the box. Barry was pretty good at keeping track of the applications. The only question is how far "UP" is.
[on edit] The 1929-1954 Parts Catalog says the same water pump repair kit fits all engines between 1937 and 1954 (and maybe later).
[another edit] The 1929-57 parts catalog doesn't list water pump repair kits, but some water pump parts, such as rotors and seals.
I kinda figured it may be for a water pump but I have never disassembled one so I didn't want to assume. Thanks folks. I am trying to figure out what things I have on the shelf that I won't need so they can find a new home.
Brendan
There is a difference between 1937-1940 water pumps and those from 1941-1953. The earlier ones had a single hole into the block, the later ones had two holes. You can clearly see that it has the gasket for the later pumps, so I would predict it is for 1941 to 1953.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Those gaskets are likely not real usable anyway, but the guts of the kit are probably usable on 37-40 water pumps based on the listing i found. The Chevy kit probably came with multiple gaskets.
