Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
Says Chevy '41 Up right on the box. Barry was pretty good at keeping track of the applications. The only question is how far "UP" is. [on edit] The 1929-1954 Parts Catalog says the same water pump repair kit fits all engines between 1937 and 1954 (and maybe later). [another edit] The 1929-57 parts catalog doesn't list water pump repair kits, but some water pump parts, such as rotors and seals.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
I kinda figured it may be for a water pump but I have never disassembled one so I didn't want to assume. Thanks folks. I am trying to figure out what things I have on the shelf that I won't need so they can find a new home.
Brendan 1940 Chevrolet 1/2-Ton Pickup Restoring Dad's old truck In the Gallery Forum
There is a difference between 1937-1940 water pumps and those from 1941-1953. The earlier ones had a single hole into the block, the later ones had two holes. You can clearly see that it has the gasket for the later pumps, so I would predict it is for 1941 to 1953. Kent
Those gaskets are likely not real usable anyway, but the guts of the kit are probably usable on 37-40 water pumps based on the listing i found. The Chevy kit probably came with multiple gaskets.
