6 members (Donf, Rustnut, Eisenholtz, TUTS 59, Hotrod Lincoln, 1 invisible), 61 guests, and 3 robots.
Topics128,203
Posts1,057,414
Members48,471
I'm looking to buy a bead blaster for my garage so I can blast all of my hinges, striker plates, etc off of my truck to get all that gunk and grease and stuff off of it. Any recommendations?
1952 Chevy 5 Window Restoration
Build your own with a kit from TIP, that way you can build it any size you want,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I use one of those cheap, stick the hose it the bucket ones.
Works for what I need with minimal investment.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
before you spend time and money on a blast cabinet, you must have a BIG, POWERFUL compressor. I have a 6hp, 60 gallon and it won't even begin to keep up with even a "bucket blaster" set up.
After two years of savings I finally got a Skat Blast cabinet from T.P.Tool. Its 46x26x26 and does a great job. I do some bead blasting for some others and it helps keep it up and "payback". TP Tool has a good section to read about air supply,how much etc that is worth the time to read. Just info....
Hmm.. a cheap one may do the job. The only thing I really need the blaster for is for cleaning the striker plates, door hinges, hood hinges.. small stuff like that. It'll only be used for the small things...
One thing that I've learned is that no matter how big the cabinet is, I always need the next size bigger sooner or later. At the museum we have a 48" cabinet. I have blasted some 6' long parts by taping a trash bag over the end door. Biggest problem is wide objects, like wheels.
And to run it we have a 15 hp compressor. You don't want to have to pay the electric bill. 40 amp, 208 volt 3 phase and it runs about 40% of the time with the blast cabinet running 55 psi.
Fred
52 3600
69 C-10
Moderated by  MNSmith
