| | | Forums66 Topics128,156 Posts1,057,020 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 56 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 56 | this may be a old question, but i did not find it in search mode. what determined which kind of e-brake these truck had?? i am talking about the ad,s 47-55 my 1950 6400 has the foot and my 1956 bus has the trans-brake.
http://www.flickr.com/photos/11977495@N06/sets/ 1952 COE 1952 3100 1953 3100 1950 6400 1951 Suburban
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | midnight auto parts,
I always figured it was the size, or series of the truck. The 1 1/2 ton and up usually had the parking brake on the rear of the transmission...my 4400 is this way.
I'm very surprised that your 6400 has a foot operated parking brake...maybe there is a different recipe for what gets which kind of brake.
Stuart | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | The one on the tranny holds about 30 times better, that I know. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | Some of the 1 tons had the tranny brake. My 1958 does. It's a slightly different brake setup than the larger trucks had on the back of their SM420, but similar in concept.
I thought everything larger than the 1 tons had the tranny brake, so I'm as supprised as you. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I see no reason one couldn't make a cable bracket and operate the transmission brake with a foot peddle if one wished. All three of my trucks have hand operated brakes at the back of the transmission. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | My two 48 1 1/2 tons have the trans mounted handle but has a cable that runs to the rear brakes. My 54 1 1/2 and 2 tons have the driveshaft brake. For parking, the driveshaft brake works good, but in an emergency, I can see the rear brake style being better. Changing a rear tire for instance.... Scott | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | My 1954 1 Ton Stake came from the factory with the foot e-brake as I believe they all did. I plan on changing it to the propeller shaft brake with the leftover parts from my 1954 2 Ton "Big Blue". I too agree the propeller shaft brake holds much better. My only concern is I'll have to modify the drive shaft (will be done by a professional), not a big deal for the extra holding power and simple mechanism. Has anybody else made this change?  | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | How about making that lever work both brakes? | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Probably wouldn't be that tough to fabricate but I really think the propeller shaft brake holds better.  | | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | Could you guys post a photo of the trans brake. My trucks is long gone - I have no emergency brake, trying to come up with one. My guess is it went where my Brownie was, but theres no sign of it anymore, thanks. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Hotshoe36, Worse case scenario.... lost brakes, broken u-joint, coming down Pikes Peak. That would be a scarry thought. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | not that great of pics, but this is what it looks like on my 56 4400... http://community.webshots.com/album/561217133LBgwym?vhost=community
Chris
1956 Chevrolet 4400 1959 Chevrolet Viking 60 1968 Chevrolet el Camino 2002 Chevrolet 1500HD 4x4
| | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | glamis4x4 thanks much for the photo's, there isnt nothing left of that brake on my truck - but now I know what it looks like, thanks again. | | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | my pleasure!
Chris
