Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Hotrod Lincoln, Rich'sToys, Peggy M, 1 invisible), 111 guests, and 5 robots.
Topics128,290
Posts1,058,558
Members48,492
this may be a old question, but i did not find it in search mode. what determined which kind of e-brake these truck had?? i am talking about the ad,s 47-55
my 1950 6400 has the foot and my 1956 bus has the trans-brake.
http://www.flickr.com/photos/11977495@N06/sets/
1952 COE
1952 3100
1953 3100
1950 6400
1951 Suburban
midnight auto parts,
I always figured it was the size, or series of the truck. The 1 1/2 ton and up usually had the parking brake on the rear of the transmission...my 4400 is this way.
I'm very surprised that your 6400 has a foot operated parking brake...maybe there is a different recipe for what gets which kind of brake.
Stuart
The one on the tranny holds about 30 times better, that I know.
1951 3800
-hotshoe
Some of the 1 tons had the tranny brake. My 1958 does. It's a slightly different brake setup than the larger trucks had on the back of their SM420, but similar in concept.
I thought everything larger than the 1 tons had the tranny brake, so I'm as supprised as you.
I see no reason one couldn't make a cable bracket and operate the transmission brake with a foot peddle if one wished. All three of my trucks have hand operated brakes at the back of the transmission.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
My two 48 1 1/2 tons have the trans mounted handle but has a cable that runs to the rear brakes. My 54 1 1/2 and 2 tons have the driveshaft brake. For parking, the driveshaft brake works good, but in an emergency, I can see the rear brake style being better. Changing a rear tire for instance....
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
My 1954 1 Ton Stake came from the factory with the foot e-brake as I believe they all did. I plan on changing it to the propeller shaft brake with the leftover parts from my 1954 2 Ton "Big Blue". I too agree the propeller shaft brake holds much better. My only concern is I'll have to modify the drive shaft (will be done by a professional), not a big deal for the extra holding power and simple mechanism. Has anybody else made this change? smile
My Trucks
Stuff I Collect
How about making that lever work both brakes?
user
Probably wouldn't be that tough to fabricate but I really think the propeller shaft brake holds better. ohwell
My Trucks
Stuff I Collect
Could you guys post a photo of the trans brake. My trucks is long gone - I have no emergency brake, trying to come up with one. My guess is it went where my Brownie was, but theres no sign of it anymore, thanks.
Big Bolt Forum Co-moderator
Hotshoe36,
Worse case scenario.... lost brakes, broken u-joint, coming down Pikes Peak. That would be a scarry thought.
1948 Chevy 2-Ton
not that great of pics, but this is what it looks like on my 56 4400... http://community.webshots.com/album/561217133LBgwym?vhost=community
Chris
1956 Chevrolet 4400
1959 Chevrolet Viking 60
1968 Chevrolet el Camino
2002 Chevrolet 1500HD 4x4
glamis4x4 thanks much for the photo's, there isnt nothing left of that brake on my truck - but now I know what it looks like, thanks again.
my pleasure! wave
Chris
1956 Chevrolet 4400
