0 members (),
136
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | Ok Bolters, here is a question for you: Due to some surgery I had to let my 1952 Chevrolet set since mid June; thankfully I'm back in fine fettle. When i went to go for a ride yesterday, I have zilch for brakes. The master clyinder is damp but empty- BUT I see no evidence of brake fluid anywhere on the floor. Anone have an idea of what is going on? Sam 1952 Chevolet 2 ton... Ole Schuyler
sam
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The fluid is inside your hydro-vac. You're gonna need a new one, the bleed your brakes again. Good luck, Scott | | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | Thanks Scott, that's exactly what my buddy and i figured, we were just looking for some confirmation. Now......anyone have a spare hydro-vac laying around? Sam
sam
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Go to your local truck power train shop, the one in my area have two in stock for about $140. I was just there getting my street rods driveshaft made so I thought I would check into it. I have a bad one too, Scott | | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | Just out of curiosity, what would cause this? When I parked it in June, after a long run the brakes were just fine. I do know that Ole Scuyler has some vacume issues, and I need to adress them.
sam
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The power train shop says that engine blow-by (unburnt petroleum)eats away the diaphram inside the hydro. Since there's a vacuum inside it, it pulls the brake fluid from the actuator side of the hydro. Take your old one with you. There's several different brands and there is a core on them, Scott | | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | hey scott, how can i tell if the hydro-vac is bad and doing this??? if i fill the master cylinder how fast will it suck it in if its bad? and not just a leaky wheel clyinder??? i know my back right is leaking slowly, plan a rebuild of wheel clyinders and master clyinder soon, how will i know for sure hydro is bad??? | | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | I was going to ask the same question re: how much grace time do we have with the brake fluid?
sam
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It's probably different for every truck. But, if you have a wheel cylinder leaking, fix that first. On mine, I would use it maybe once a week if not less. Every time I would go get it, the master was dry and the pedal went to the floor. An external leak that big would show itself in a big way. I didn't have time to replace it at the time so I by-passed it and I haven't lost a drop since. Scott | | | | | Joined: Aug 2006 Posts: 22 Apprentice | | Apprentice Joined: Aug 2006 Posts: 22 | Scott: I went to a couple of local shops here in search of a hydro-vac and they looked at me as if i had a thrid eye. Might I get the name and phone number for your guys? Thanks, Sam
sam
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Sure, It's Sadler Power Train Inc. in Cedar Rapids, Iowa. Phone number is 319-366-8238, Good luck, Scott | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | | | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | hey jeff, didnt look too hard, but where do i find a rebuild kit???? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I got mine from ABS power brake, If you call them ask for Doug.
Most good brake shops should have kits but I dont think most of them like to sell the kits so you may have to argue with them to get one. Id try locally first so you can look at the parts before you buy and make sure you get what you need. Different kits have different pieces, plus theres different seal sizes on the small to larger units.
Jeff | | |
