Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Svcattle, baldeagle), 145 guests, and 1 robot.
Topics128,274
Posts1,058,432
Members48,489
#155289 10/06/2007 10:13 PM
Apprentice
Apprentice
Ok Bolters, here is a question for you:
Due to some surgery I had to let my 1952 Chevrolet set since mid June; thankfully I'm back in fine fettle. When i went to go for a ride yesterday, I have zilch for brakes. The master clyinder is damp but empty- BUT I see no evidence of brake fluid anywhere on the floor. Anone have an idea of what is going on?
Sam
1952 Chevolet 2 ton... Ole Schuyler
sam
#155290 10/06/2007 11:10 PM
The fluid is inside your hydro-vac. You're gonna need a new one, the bleed your brakes again.
Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#155291 10/07/2007 3:08 AM
Apprentice
Apprentice
Thanks Scott, that's exactly what my buddy and i figured, we were just looking for some confirmation. Now......anyone have a spare hydro-vac laying around?
Sam
sam
#155292 10/07/2007 4:32 AM
Go to your local truck power train shop, the one in my area have two in stock for about $140. I was just there getting my street rods driveshaft made so I thought I would check into it. I have a bad one too,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#155293 10/07/2007 2:21 PM
Apprentice
Apprentice
Just out of curiosity, what would cause this? When I parked it in June, after a long run the brakes were just fine. I do know that Ole Scuyler has some vacume issues, and I need to adress them.
sam
#155294 10/07/2007 2:33 PM
The power train shop says that engine blow-by (unburnt petroleum)eats away the diaphram inside the hydro. Since there's a vacuum inside it, it pulls the brake fluid from the actuator side of the hydro. Take your old one with you. There's several different brands and there is a core on them,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#155295 10/08/2007 1:01 PM
hey scott, how can i tell if the hydro-vac is bad and doing this??? if i fill the master cylinder how fast will it suck it in if its bad? and not just a leaky wheel clyinder??? i know my back right is leaking slowly, plan a rebuild of wheel clyinders and master clyinder soon, how will i know for sure hydro is bad???
nothin like ol' Chevy iron..keep it goin
1948 Chevy Loadmaster Flatbed
#155296 10/08/2007 1:23 PM
Apprentice
Apprentice
I was going to ask the same question re: how much grace time do we have with the brake fluid?
sam
#155297 10/08/2007 11:21 PM
It's probably different for every truck. But, if you have a wheel cylinder leaking, fix that first. On mine, I would use it maybe once a week if not less. Every time I would go get it, the master was dry and the pedal went to the floor. An external leak that big would show itself in a big way. I didn't have time to replace it at the time so I by-passed it and I haven't lost a drop since.
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#155298 10/09/2007 2:57 AM
Apprentice
Apprentice
Scott:
I went to a couple of local shops here in search of a hydro-vac and they looked at me as if i had a thrid eye.
Might I get the name and phone number for your guys?
Sam
sam
#155299 10/09/2007 4:12 AM
Sure,
It's Sadler Power Train Inc. in Cedar Rapids, Iowa. Phone number is 319-366-8238,
Good luck,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#155300 10/09/2007 4:20 AM
In case your interested...
I wrote a tech tip on overhauling these.
Jeff
My 1953 Chevrolet
1947.1 Gallery
#155301 10/09/2007 2:35 PM
hey jeff, didnt look too hard, but where do i find a rebuild kit????
#155302 10/09/2007 3:57 PM
I got mine from ABS power brake, If you call them ask for Doug.
Most good brake shops should have kits but I dont think most of them like to sell the kits so you may have to argue with them to get one. Id try locally first so you can look at the parts before you buy and make sure you get what you need. Different kits have different pieces, plus theres different seal sizes on the small to larger units.
Jeff
My 1953 Chevrolet
1947.1 Gallery
