7 members (JW51, baldeagle, Oswald, Gdads51, Jay R, greenie-reddy, 1 invisible),
43
Mod | | | Forums66 Topics128,004 Posts1,055,247 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 89 | Hello, I can't seem to find my front shocks for my 1960 C-60. Napa didn't list em' or so they said, neither did a couple of other places. Any sugesstions? Cross refrences to other years etc... Thanks!
240,000 worker bees! 1960 Two ton Chevy
| | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Have you checked with yer local Chevy truck dealer?? Some of the smarter parts guys keep the old parts books...
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Stick,
Just saw where you have a JD 420C. The 420's were made from 1956 to 1958. You can check what year it is for sure if you still have your serial number tag. I have a JD 435.
Beewrangler,
If you still are having trouble finding the original GM numbers, let me know and I can check in my parts book.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I've never felt the need for shocks on the bigger trucks. There isn't enough bounce to them for shocks to do any good, Scott | | | | | Joined: Jan 2007 Posts: 63 New Guy | | New Guy Joined: Jan 2007 Posts: 63 | 48 Big Trucks said: I've never felt the need for shocks on the bigger trucks. There isn't enough bounce to them for shocks to do any good.
Interesting you mentioned that. On my `67 C-50, I noticed that the front suspension isn't hard on bumps, but the rear suspension is. This is w/ no additional load added. I found that the lower rubber shock bushings are rotted to the point where the shocks are hanging from the top mounts & serving no function. The shocks are severly rusted & I was thinking replacing the shocks will be necessary. Maybe I can get away w/ just replacing the rubber bushings. Maybe I'll try that. Are your shocks mounted? How old are your leaf springs & shocks what shape are they in? Do you load your truck up a a lot of weight? | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Beewrangler My 64 GMC has shocks I'll see if I can find some numbers on them for you. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have driven several of my trucks without shocks, 1.5 or 2 ton springs up to 45 or 50 mph shocks don't seem to make much difference. Much faster and shocks make a noticeable difference, at least in the front.
Grigg | | |
