8 members (Rusty Heaps, Frank50, BarryP, UtahYork, cmayna, DadsFirstPickup, Gray_Ghost, 1 invisible), 138 guests, and 2 robots.
Topics128,134
Posts1,056,738
Members48,454
#1539157 03/06/2024 3:19 AM
Just checking to see if anyone has ever purchased a short shaft water pump for Mother Trucker Truck off of ebay?
It a bit expensive I know (340$ USD). It's what I need for my 261 in the AD truck. Comes with the pulley. Says it's made in USA. Don't mind paying a little more for it if thats true and it's good quality. Anyone have knowledge of this product?
Jeff
1964 Chevrolet K10 Fleetside
"A Kid's First Truck"
Follow in the DITY
1951 Chevrolet 3100
Follow his build in the Project Journals
1969 Chevrolet Camaro Convertible | 2020 Chevrolet Silverado | 3500 Duramax | 2021 GMC Sierra Denali
USAF Veteran 1983-1987 | PSP retired 1990- 2012
Seems rather high. Jim Carter has the same thing for $170.
https://oldchevytrucks.com/reme205.html
I bought one from Carter several years ago and it works great. If I had to do it again, I would buy the early pump and use the adapter.
1951 3100
I used the adapter and got waterpump from Oriellys for $40 about 5 years ago for my 261 engine.
I checked on one for a friend and Oriellys was $90 just a few weeks ago. Folks will take your money if you let them.
1 Offline
I made my own short shaft water pump by pressing the flange on the required extra amount and cutting the shaft after it was done. I've done this twice with good results. Now, I'd like to rebuild an extra pump for the future. Where can I get bearings and seals for the pump?
1951 3800 1-ton
In the DITY Gallery
What about pulleys . What I've read here is always an issue. Most places like Carters if you put it in the cart, It tells you it will ship when available.
Jeff
Follow in the DITY
1951 Chevrolet 3100
1 Offline
If someone uses the original size pulley, it'll spin the fan too fast and maybe throw a blade through the hood. Watch the pulley sizes. I should expand on my post to say that I was using the late pump and a 2-shiv pulley from an air-conditioned V8.
1951 3800 1-ton
In the DITY Gallery
Machine the original pulley sheave off the 216 pump, leaving the hub where the fan bolts on. Use a stamped steel pulley for a Ford small block V8- - - -302 or 351. They come with either one or two belt grooves. That solves the pump speed problem.
Thanks Jerry.
I will search one out.
Jeff
Follow in the DITY
1951 Chevrolet 3100
