| | | Forums66 Topics128,090 Posts1,056,371 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2023 Posts: 283 'Bolter | | 'Bolter Joined: Nov 2023 Posts: 283 | Just checking to see if anyone has ever purchased a short shaft water pump for Mother Trucker Truck off of ebay? It a bit expensive I know (340$ USD). It's what I need for my 261 in the AD truck. Comes with the pulley. Says it's made in USA. Don't mind paying a little more for it if thats true and it's good quality. Anyone have knowledge of this product? | | | | | Joined: Jan 2014 Posts: 3,689 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,689 | Seems rather high. Jim Carter has the same thing for $170. https://oldchevytrucks.com/reme205.htmlI bought one from Carter several years ago and it works great. If I had to do it again, I would buy the early pump and use the adapter.
1951 3100
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I used the adapter and got waterpump from Oriellys for $40 about 5 years ago for my 261 engine. I checked on one for a friend and Oriellys was $90 just a few weeks ago. Folks will take your money if you let them. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | I made my own short shaft water pump by pressing the flange on the required extra amount and cutting the shaft after it was done. I've done this twice with good results. Now, I'd like to rebuild an extra pump for the future. Where can I get bearings and seals for the pump? 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Nov 2023 Posts: 283 'Bolter | | 'Bolter Joined: Nov 2023 Posts: 283 | What about pulleys . What I've read here is always an issue. Most places like Carters if you put it in the cart, It tells you it will ship when available. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | If someone uses the original size pulley, it'll spin the fan too fast and maybe throw a blade through the hood. Watch the pulley sizes. I should expand on my post to say that I was using the late pump and a 2-shiv pulley from an air-conditioned V8. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | Machine the original pulley sheave off the 216 pump, leaving the hub where the fan bolts on. Use a stamped steel pulley for a Ford small block V8- - - -302 or 351. They come with either one or two belt grooves. That solves the pump speed problem. Jerry
| | | | | Joined: Nov 2023 Posts: 283 'Bolter | | 'Bolter Joined: Nov 2023 Posts: 283 | Thanks Jerry. I will search one out. | | |
