2 members (Hotrod Lincoln, Stewart2), 125 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
ok guys, whats the best type of gaskets for the top cowl and side cab vents on a 48 loadmaster that will seal it the best but still be usable? rubber or foam?
nothin like ol' Chevy iron..keep it goin
1948 Chevy Loadmaster Flatbed
Foam rubber. Just kiddin,,the ones from the repro suppliers are about the only pieces iv had good luck with.
If youre going to make your own,,just make sure you use "closed cell" foam. It doesnt act as a sponge and hold water in.
Marty
My experience is only on my 37, so far, but suspect it may be on others. I used the rubber gasket and it is much thicker and has no "give" later on. The thicker rubber will not let the top cowl vent close as tight. I have been meaning to actually change the rubber one out.
Edit: I notice your from Dripping Springs. We have another Bolter from there. If you don't know him stick around and he'll show up.
