3 members (Hush, Peggy M, 1 invisible),
116
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | ok guys, whats the best type of gaskets for the top cowl and side cab vents on a 48 loadmaster that will seal it the best but still be usable? rubber or foam? | | | | | Joined: Nov 2001 Posts: 1,522 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,522 | Foam rubber. Just kiddin,,the ones from the repro suppliers are about the only pieces iv had good luck with. If youre going to make your own,,just make sure you use "closed cell" foam. It doesnt act as a sponge and hold water in. Marty | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | My experience is only on my 37, so far, but suspect it may be on others. I used the rubber gasket and it is much thicker and has no "give" later on. The thicker rubber will not let the top cowl vent close as tight. I have been meaning to actually change the rubber one out.
Edit: I notice your from Dripping Springs. We have another Bolter from there. If you don't know him stick around and he'll show up. | | |
