| | | Forums66 Topics128,154 Posts1,056,835 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | whats the best size tires to run all the way around on my 1948 loadmaster? | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I use 8.25 x 20R. Radials make a world of difference to the steering. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I agree with Va.FireTruck. 8.25 X 20, is a good size for your truck. It would have came standard from the factory 7.50 X 20 front, & 8.25 X 20 rear. I've got 8.25's, all the way around, on my '46 Chevy 2 ton, & '53 Chevy COE 2ton. | | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | is it hard to find folks to mount these split rim tires? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I just mounted two fronts tonight. You need to make sure you have the wider wheels to mount the 8.25's on. Most 7.50 wheels are an inch narrower than the 8.25 wheels, Scott | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Any tire shop that sells big truck tires will do it as well as truck stops...
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Apr 2007 Posts: 26 Apprentice | | Apprentice Joined: Apr 2007 Posts: 26 | 8.25 X 20 are on my 1950 6400. Just looks right too !  | | | | | Joined: Mar 2007 Posts: 173 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 173 | 7.50x20's all the way around on mine. I ended up mounting them myself rather than hunt all over town to try and find someone to do them. | | |
