4 members (Danielbolt, 59 fleet, klhansen, TooMany2count), 116 guests, and 1 robot.
Topics128,157
Posts1,056,874
Members48,456
whats the best size tires to run all the way around on my 1948 loadmaster?
V
V Offline
I use 8.25 x 20R. Radials make a world of difference to the steering.
I agree with Va.FireTruck. 8.25 X 20, is a good size for your truck. It would have came standard from the factory 7.50 X 20 front, & 8.25 X 20 rear. I've got 8.25's, all the way around, on my '46 Chevy 2 ton, & '53 Chevy COE 2ton.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
is it hard to find folks to mount these split rim tires?
I just mounted two fronts tonight. You need to make sure you have the wider wheels to mount the 8.25's on. Most 7.50 wheels are an inch narrower than the 8.25 wheels,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Any tire shop that sells big truck tires will do it
as well as truck stops...
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
MJD Offline
Apprentice
Apprentice
8.25 X 20 are on my 1950 6400. Just looks right too !
smile
7.50x20's all the way around on mine. I ended up mounting them myself rather than hunt all over town to try and find someone to do them.
