1 members (Hotrod Lincoln),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 21 Apprentice | | Apprentice Joined: Jan 2007 Posts: 21 | Earlier in January or February I started a topic about the little strip of wood between the hoist frame and the truck frame.
I was (and am) very hesitant to put wood back in there because I feel it will just deteriorate in time just like the last strip of wood.
So, I came up with the idea of using a length of bailer belt. Thick rubber with some type of fiber sandwitched between for strength. Would anyone know why I shouldn't use bailer belt strips instead of wood strips between the frames? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Should work, but I would want to hear from someone who has used it, it could squeak allot?
New truck bodies are most often attached with wood between. I have seen the exact same dimensions and material on many different newer trucks, so someone sells wood for the express purpose of installing it between a body and frame. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | rubber may have a greater tendency to flex and give causing your bed to shift or loosen. some bodies i've seen have nothing between frame of truck and body don't know if thats a good idea or not they were just tack welded direct to frame then bolted | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I've removed bodies from 50, & 60 year old trucks, & never found the wood to be deteriated. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I have used body welting,available by the roll from Total Performance in Wallingford CT. and other suppliers.Another idea is CCA.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I would use wood soaked in linseed oil or some other kind of oily preservative. Most of my beds have the wood buffer but I also have one that only has a bracket mounted to the frame for the bed to "land" on when down. It's steel on steel, don't know if that's correct or if there should be a silencer of some sort there. Scott | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | One purpose for the wood strip is, if you have rivet heads sticking up on the top side of the frame, you can countersink them into the wood so you have a flat surface on top for the bed to rest on. | | |
