0 members (), 61 guests, and 1 robot.
Topics128,049
Posts1,055,743
#153044 06/03/2007 4:24 AM
Apprentice
Apprentice
Earlier in January or February I started a topic about the little strip of wood between the hoist frame and the truck frame.
I was (and am) very hesitant to put wood back in there because I feel it will just deteriorate in time just like the last strip of wood.
So, I came up with the idea of using a length of bailer belt. Thick rubber with some type of fiber sandwitched between for strength. Would anyone know why I shouldn't use bailer belt strips instead of wood strips between the frames?
#153045 06/03/2007 5:55 AM
Should work, but I would want to hear from someone who has used it, it could squeak allot?
New truck bodies are most often attached with wood between. I have seen the exact same dimensions and material on many different newer trucks, so someone sells wood for the express purpose of installing it between a body and frame.
1952 Chevrolet 3800 pickup
---All pictures---
#153046 06/03/2007 11:18 AM
rubber may have a greater tendency to flex and give causing your bed to shift or loosen. some bodies i've seen have nothing between frame of truck and body don't know if thats a good idea or not they were just tack welded direct to frame then bolted
#153047 06/03/2007 2:00 PM
I've removed bodies from 50, & 60 year old trucks, & never found the wood to be deteriated.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#153048 06/03/2007 4:08 PM
I have used body welting,available by the roll from Total Performance in Wallingford CT. and other suppliers.Another idea is CCA.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#153049 06/03/2007 5:44 PM
I would use wood soaked in linseed oil or some other kind of oily preservative. Most of my beds have the wood buffer but I also have one that only has a bracket mounted to the frame for the bed to "land" on when down. It's steel on steel, don't know if that's correct or if there should be a silencer of some sort there.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#153050 06/03/2007 8:41 PM
One purpose for the wood strip is, if you have rivet heads sticking up on the top side of the frame, you can countersink them into the wood so you have a flat surface on top for the bed to rest on.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
