BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
1 members (Movingeric),
487
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,270 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | Shop Shark Joined: Jan 2005 Posts: 1,602 | You are amazing. I love the way the axle looks when you finished gringing and welding it. It looks new like it came in that size.
You have talent and a real imagination. Nice job! | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | Shop Shark Joined: Sep 2006 Posts: 1,276 | Nice job Grigg that shop truck sure had the squats picking that 6V-53. What dose the lettering on the door say? Can't read it in the picture. You know if those notches bother you, you could always throw a bead at each end of you adapter plates that would add some triangulation support to the ends of the axle. Anyway nice job. | | | | Joined: May 2005 Posts: 8,877 . | . Joined: May 2005 Posts: 8,877 | The lettering the door says "POS". I thought about welding the ends of the adapter plates, but decided it would be a bad idea. I think that things may flex to much, and the weld would crack. What I would do is grind just a little off of the axle where the plate almost meets it. So the gap would be parallel, and it would be about 5/16" Then I would weld a piece of key stock, or anything really, that would just fill the gap. then if the axle did try to bend it would be supported buy the plates. But it really does not bother me.
Grigg | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | Wrench Fetcher Joined: Aug 2005 Posts: 113 | Grigg,
After all that work, why don't you swap out the F*rd body for a Chev or GMC body?
I hope that the original frame is up to carrying around all that weight!
Lane | | | | Joined: May 2005 Posts: 8,877 . | . Joined: May 2005 Posts: 8,877 | I did use a GMC steering wheel and horn button, that has to help some. The sheet metal on it is rust free, so no real reason to change it. I too think that he frame could be heavier for what the truck is now, but it shows no signs of weakness, it is double framed for a good portion, that helps.
I have always said I will drive anything that runs. But after working on this and some other fords I really do prefer to play with GM stuff.
I bought this truck for the adventure of driving it home from CA. As well as to learn from how it was put together / converted. Also to play with a Detroit, as my real project, the 48 with a 4-53T is still a few years away from driving. I for the most part enjoyed swapping the axles and related goodies, and learned a lot from doing it.
This truck was never intended to be a permanent member of the family, just something to play with for a little while and come out even or, if I am lucky, make a little money.
I am about done with it. I still need to have the bed liner sprayed on the cab floor, and replace the sleeper seal. Have some more steam cleaning done so I can find and stop the last few dribbles, and that's it.
I will drive it to the ATHS truck show in Colorado Springs in about two weeks, and hopefully I'll have to find a different ride home.
Grigg | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | Shop Shark Joined: Sep 2006 Posts: 1,276 | The Detroit is GM and with the wheel in it, it just looks like a ford.  | | | | Joined: Jul 2006 Posts: 482 Shop Shark | Shop Shark Joined: Jul 2006 Posts: 482 | Grigg, You are the master inovator. McGiver on wheels.  | | | | Joined: May 2005 Posts: 8,877 . | . Joined: May 2005 Posts: 8,877 | I went to the junk yards with a completely open mind looking for suitable parts. The goal was to improve the truck in the most reliable, simple, and cheapest way possible, in about that order. I had no brand preference, price and suitability were the deciding factors.
Looking back I find it interesting that of all new used parts I ended up with, choosing from literally 100's of possible donors, that all but one part came from a ford. The vast majority of the parts came from GMC trucks, and a few from Freightliner and KW trucks. I did find a suitable steering shaft u-joint from a ford f700, but that's all I found useful from all the fords I looked at.
Perhaps GM vehicles truly are a little better than fords, at least the individual parts are more useful.
Grigg | | | | Joined: May 2006 Posts: 237 Shop Shark | Shop Shark Joined: May 2006 Posts: 237 | Grigg,
You have definitely cobbled together an interesting rig. Looks like it'll be pretty strong as well. If you sell it at the show let us know how much you got for it.
I wish I knew what time you'd be driving through the St. Louis area, I'd park on the highway just so I could hear you drive by. | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | Shop Shark Joined: Dec 2003 Posts: 2,733 | "The sheet metal on it is rust free"
What about that great big hole in the floor board? Do you think RhinoLiner will fix that? | | | | Joined: May 2005 Posts: 8,877 . | . Joined: May 2005 Posts: 8,877 | What hole? It has a few extra holes cut in the floor that I will repair, but no rust... Grigg | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | Shop Shark Joined: Sep 2006 Posts: 1,276 | Easy Dave I think you may have rubbed a sore spot there. He has pictures posted of the in side of the cab. I didn't see any hole. Now my 64 that has floor board holes. | | | | Joined: Feb 2002 Posts: 61 Member | Member Joined: Feb 2002 Posts: 61 | Very nice axle narrowing.....
1948 Dodge 2 ton 1950 GMC 1 1/2 ton 1952 GMC 3/4 ton
| | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | Wrench Fetcher Joined: Feb 2006 Posts: 162 |
Chris
1956 Chevrolet 4400 1959 Chevrolet Viking 60 1968 Chevrolet el Camino 2002 Chevrolet 1500HD 4x4
| | | | Joined: Jan 2007 Posts: 50 Member | Member Joined: Jan 2007 Posts: 50 | A lot of people talk about doing, you did it. Talk is cheap work is time.
restoring a 1946 coe wrecker.
| | | | Joined: Feb 2006 Posts: 222 Shop Shark | Shop Shark Joined: Feb 2006 Posts: 222 | Grigg, my hat is off to you! Rick | | |
