7 members (Donf, King Kielbasa, jmoore, Gdads51, cmayna, 2-Ton, 1 invisible),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,169 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | well..i have a 50 chev 4400(decided to fix it up)..I have a different 216 engine i'm trying to hook onto the 4 speed tranny..i'm having a Heck of a time trying to do this by myself..I used to put tranny's in Half-ton chev's by myself....just put them on my Chest and Shove-it in back of the engine...I can't with this Tranny,(Too dang Heavy) ,if i did,and dropped the tranny..i'd be a Goner..Any Help PLEASE... :confused:  | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | The best way I have found to do this is with a transmission jack. You can stabalize the transmission on the jack and not have to wear it. I am sure that you can rent one from a rental place. It is well worth the cost just to be on the safe side. Good luck Jim | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've heard of people using a cherry picker to lift the transmission working through the cab. Don't know if that will help you or not.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I did it once by myself. I tied a rope around it, sat on the seat and picked it up, then somehow with a foot I got it stuck in place. I deciede to never try that again. Two people are a must with no transmission jack. | | | | | Joined: Sep 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 191 | I've sat jack stands in both floor boards and put a pipe across them and used ratchet straps to raise them into place before. Seems when you work alone you come up with some of this stuff LOL. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 50chevy,
I once did it myself over 30 years ago - never again.
I have trained an ex-Marine friend to help as a 4-speed raiser/lowerer. No matter how you raise or lower the transmission, you might want to get two long bolts the same size as the mounting bolts; cut off the bolts heads; and, screw them into the top mounting holes in the clutch housing, to serve as pilot bolts. This has worked quite well for me (in recent years).
Tim | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | on a 66 GMC, I blocked the tranny up, disconnected everything, and pushed the truck away from the tranny (dont forget to put a rolling jack under the engine if it has side mounts). I changed out the clutch ect and pushed the truck back to the tranny... all it took was a bit of wiggling to get it back in place... :hammering:
| | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | when i rebuilt the 4 speed in my 49 3600, i bench pressed mine back up into place and had my dad start the bolts, but at the same time, i and 6' 4" 300 pounds, 18 years old (i turned down a few football scholarships) and can bench press 325 pounds, and it was a little tricky, so i'd say get a jack 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | I used my motorcycle lift and even with that I had difficulty. Was about to call it quits and get help when it slid in, I used the guide pinns as mentioned above and a ratchet strap too. I like the sound of moving the truck - that never accured to me. | | | | | Joined: Mar 2007 Posts: 3,440 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,440 | I have done it by removing the tunnel cover and using a come-a-long and 4X4 blocks(2.5 ton Army truck). Just lift it into position and get a couple of bolts started, you could use some old head bolts as alignment studs. It's safer than laying under a heavy tranmission. Good luck.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Aw I just did this on my 64 GMC used a cherry picker through the door and some long studs like the bolts that where mentioned above. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | |
