1 members (KEVINSKI), 119 guests, and 2 robots.
Topics128,162
Posts1,056,943
Members48,458
#152486 05/06/2007 4:44 AM
well..i have a 50 chev 4400(decided to fix it up)..I have a different 216 engine i'm trying to hook onto the 4 speed tranny..i'm having a Heck of a time trying to do this by myself..I used to put tranny's in Half-ton chev's by myself....just put them on my Chest and Shove-it in back of the engine...I can't with this Tranny,(Too dang Heavy) ,if i did,and dropped the tranny..i'd be a Goner..Any Help PLEASE... :confused: eek ohwell
#152487 05/06/2007 5:54 AM
J M Offline
The best way I have found to do this is with a transmission jack. You can stabalize the transmission on the jack and not have to wear it. I am sure that you can rent one from a rental place. It is well worth the cost just to be on the safe side.
Good luck
Jim
#152488 05/06/2007 5:55 AM
I've heard of people using a cherry picker to lift the transmission working through the cab. Don't know if that will help you or not.
#152489 05/06/2007 1:44 PM
I did it once by myself. I tied a rope around it, sat on the seat and picked it up, then somehow with a foot I got it stuck in place. I deciede to never try that again. Two people are a must with no transmission jack.
•1952 Chevrolet 3800 pickup
---All pictures---
#152490 05/06/2007 1:51 PM
I've sat jack stands in both floor boards and put a pipe across them and used ratchet straps to raise them into place before. Seems when you work alone you come up with some of this stuff LOL.
#152491 05/06/2007 2:07 PM
50chevy,
I once did it myself over 30 years ago - never again.
I have trained an ex-Marine friend to help as a 4-speed raiser/lowerer. No matter how you raise or lower the transmission, you might want to get two long bolts the same size as the mounting bolts; cut off the bolts heads; and, screw them into the top mounting holes in the clutch housing, to serve as pilot bolts. This has worked quite well for me (in recent years).
Tim
#152492 05/06/2007 3:31 PM
on a 66 GMC, I blocked the tranny up, disconnected everything, and pushed the truck away from the tranny (dont forget to put a rolling jack under the engine if it has side mounts). I changed out the clutch ect and pushed the truck back to the tranny... all it took was a bit of wiggling to get it back in place... :hammering:
Another quality post.
Real Trucks Rattle
#152493 05/06/2007 6:02 PM
when i rebuilt the 4 speed in my 49 3600, i bench pressed mine back up into place and had my dad start the bolts, but at the same time, i and 6' 4" 300 pounds, 18 years old (i turned down a few football scholarships) and can bench press 325 pounds, and it was a little tricky, so i'd say get a jack
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#152494 05/07/2007 1:33 AM
I used my motorcycle lift and even with that I had difficulty. Was about to call it quits and get help when it slid in, I used the guide pinns as mentioned above and a ratchet strap too. I like the sound of moving the truck - that never accured to me.
#152495 05/07/2007 5:30 AM
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
I have done it by removing the tunnel cover and using a come-a-long and 4X4 blocks(2.5 ton Army truck). Just lift it into position and get a couple of bolts started, you could use some old head bolts as alignment studs. It's safer than laying under a heavy tranmission. Good luck.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
#152496 05/07/2007 6:09 AM
Aw I just did this on my 64 GMC used a cherry picker through the door and some long studs like the bolts that where mentioned above.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#152497 05/07/2007 11:02 PM
