0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I'm trying to figure out what it'll cost to drive the new/old '57 GMC dump truck I got home next time I come to Reno. It's a 1957 GMC 350 dump truck with a 270 six,SM420 4 speed,and 2 speed axle,and 22.5 wheels. Can anybody with a similar set up give me some idea what mileage it might get? I don't run more than 60 mph,and don't plan any stops other than gas and coffee. Thanks for any info you choose to share! Speed | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | My 64 two ton GMC with a more modern 350 SB Chevy an SM420 and a two speed rear gets about 6 MPG and she is screaming at 55. I don't know for sure but chances are it gets better mileage with the 350 than it did with the stock 292. The SB is a little happier at the higher RPM than the original six. Oh and it seems too get about the same empty or loaded. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Oh and yes it gets worse mileage than my old 8 axle KW dump truck at 105,500 pounds with a 550 CAT and an 18 speed. I load the GMC to 26,000 GVW and 31,380 CGVW with the 12 ton equipment trailer and 17,000 pound 307 cat excavator behind it. Dragging 23,000 pounds of trailer and machine is a slow go drops MPG to about 4 and I am sure it is shorting the life of the transmission. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Knowing your rear gears and total weight would help in guessing this right, but I'd bet 6 mpg is optimistic and running 60 mph impossible.
Your gearing was chosen to get a very heavy load moving, not to move an empty truck fast.
I don't recall how hilly the drive form Reno to Elko is. I'm thinking you will be going down in elevation, but if you are climbing much, that will be slow going too.
300 miles? At 5 mpg you'll burn 60 gallons. If it only has a stock tank you'll be stopping a few times for fuel and coffee...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Anyone know what a 261 in a 2 ton truck gets? Ballpark... Just wondering what it will cost me to drive it on a 200 mile round trip. Thanks. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Originally posted by Virginiafiretruck: Anyone know what a 261 in a 2 ton truck gets? Ballpark... Just wondering what it will cost me to drive it on a 200 mile round trip. Thanks. If you have to ask....  | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Yea with gas as high as it is, I guess I already knew the answer. :-) | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Bring a high limit credit card, gas cans and a cell phone and enjoy the trip. Fuel economy is a mute point in the old truck world. If it ain't burning it, it's leaking it (or is that the oil?), Scott | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | Milage? You're kidding right? I'd guess somewhere in the range of an M1 Abrahms tank! :p
If it were me,... I'd say get a 55 gallon drum with a hand-op fuel pump, strap it in the fwd. left corner of the bed. Top off the truck and the drum, grab a thermos of coffee, & have a nice trip.
I did some number crunching on my nifty gear ratio calculator for my beastie once, gave me a blazin top speed of 53MPH in my '56 370 dump. That was being conservative since I didn't have exact numbers tho.
BTW, if any of you folks wanna give me the diameter of the tire, the gear ratio/s for your rear end, the ratio for your highest gear (or all of them if ya have em), and the RPM limit of the engine, I can get you the exact speed limitations for your rig. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I guess you're right about the mileage. I'm just gonna take all the money I can pull together and stop at every town on the way for gas. Hevyhauler; You're probably right about 60 mph. No big deal,I'll just set the road speed at whatever makes the engine happy. I plan to take my '45 Mack for a short test run on the highway (30 miles or so) to see how it's gonna handle the trip. I just talked to a friend up in Elko who offered to bring his tractor trailer down and haul my trucks back for me,so if the Mack passes the road test I'll go ahead and drive it back towing the '62 one ton,but if it fails(not enough power to maintain high gear,too roadwild,etc.)I'll just have the Mack and the GMC hauled and drive my one ton. OldSub; The drive from Reno to Elko's mostly relatively flat ground with a total climb from about 3,500 ft. to 5,100 ft. and 3 passes to go over. Nothing really extreme. BTW-we got the boom finished today,I tested it by swinging it out to the right and picking the rear of Dutch's Ford Ranger up off the ground a couple of feet. (He wasn't very amused...)I'm sure it'll be strong enough. Speed | | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | do you have any pictures of the boom on the mack
Now boltless but looking 1951 F-1 350/350 1965 Mustang 355 glide 1971 F-100 401 fe it hates me 1972 Maverick 302 c4
| | | | | Joined: Jul 2006 Posts: 149 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 149 | Come on guys...... It's NOt miles-per-gallon..... With old trucks... (especially BIG trucks)... You need to remember one thing.... Gallons-per mile.. Michael \'48 chev 2-ton boom truck (Boomer) '49 Chev 2-ton flat bed '65 Chev 35ft school bus '88 GMC 6500 '72 Superior 26ft class "A" coach '50 Farmall "M" '71 MGB GT '68 Austin-Healey Sprite '65 Austin-Healey Sprite and various other odd British cars and lots of old radios..... Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Really...what does a 2 ton with a 261 get for MPG? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Graflexmaster: Come on guys...... It's NOt miles-per-gallon..... With old trucks... (especially BIG trucks)... You need to remember one thing.... Gallons-per mile.. Michael No, no, no... Its SMILES per mile!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I used to drive a 60 school bus that was rated at 2 tons. Had 4speed trans, single speed rear axle. It would run 60 empty fairly easily, but only got about 6 mpg on the road. It had the 261 6. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Sounds like a school buss rear axle may have the gears that some of the guys are looking for. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | It would run down the road fairly easily at 60. Still had a good bit of power to climb hills. This was in a 1960 Viking chasis with a 48 pass Wayne coach on it. Had the old split rims on it. Always hated working on those. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I've had it to 45 MPH but it had bad brakes then. I'll give it a try once I get it all back together again with the new brakes... I'll let you know. | | |
