2 members (Wheelie, 78buckshot), 78 guests, and 1 robot.
Topics128,050
Posts1,055,643
#152302 04/29/2007 7:48 AM
I'm trying to figure out what it'll cost to drive the new/old '57 GMC dump truck I got home next time I come to Reno. It's a 1957 GMC 350 dump truck with a 270 six,SM420 4 speed,and 2 speed axle,and 22.5 wheels.
Can anybody with a similar set up give me some idea what mileage it might get? I don't run more than 60 mph,and don't plan any stops other than gas and coffee.
Thanks for any info you choose to share!
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#152303 04/29/2007 6:00 PM
My 64 two ton GMC with a more modern 350 SB Chevy an SM420 and a two speed rear gets about 6 MPG and she is screaming at 55. I don't know for sure but chances are it gets better mileage with the 350 than it did with the stock 292. The SB is a little happier at the higher RPM than the original six. Oh and it seems too get about the same empty or loaded.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#152304 04/29/2007 6:18 PM
Oh and yes it gets worse mileage than my old 8 axle KW dump truck at 105,500 pounds with a 550 CAT and an 18 speed. I load the GMC to 26,000 GVW and 31,380 CGVW with the 12 ton equipment trailer and 17,000 pound 307 cat excavator behind it. Dragging 23,000 pounds of trailer and machine is a slow go drops MPG to about 4 and I am sure it is shorting the life of the transmission.
user
#152305 04/29/2007 9:15 PM
Knowing your rear gears and total weight would help in guessing this right, but I'd bet 6 mpg is optimistic and running 60 mph impossible.
Your gearing was chosen to get a very heavy load moving, not to move an empty truck fast.
I don't recall how hilly the drive form Reno to Elko is. I'm thinking you will be going down in elevation, but if you are climbing much, that will be slow going too.
300 miles? At 5 mpg you'll burn 60 gallons. If it only has a stock tank you'll be stopping a few times for fuel and coffee...
#152306 04/29/2007 11:42 PM
V
V Offline
Anyone know what a 261 in a 2 ton truck gets? Ballpark... Just wondering what it will cost me to drive it on a 200 mile round trip. Thanks.
#152307 04/30/2007 2:17 PM
Quote
If you have to ask.... grin
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#152308 04/30/2007 11:02 PM
V
V Offline
Yea with gas as high as it is, I guess I already knew the answer. :-)
#152309 05/01/2007 2:31 AM
Bring a high limit credit card, gas cans and a cell phone and enjoy the trip. Fuel economy is a mute point in the old truck world. If it ain't burning it, it's leaking it (or is that the oil?),
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#152310 05/04/2007 5:29 AM
Milage? You're kidding right? I'd guess somewhere in the range of an M1 Abrahms tank! :p
If it were me,...
I'd say get a 55 gallon drum with a hand-op fuel pump, strap it in the fwd. left corner of the bed. Top off the truck and the drum, grab a thermos of coffee, & have a nice trip.
I did some number crunching on my nifty gear ratio calculator for my beastie once, gave me a blazin top speed of 53MPH in my '56 370 dump. That was being conservative since I didn't have exact numbers tho.
BTW, if any of you folks wanna give me the diameter of the tire, the gear ratio/s for your rear end, the ratio for your highest gear (or all of them if ya have em), and the RPM limit of the engine, I can get you the exact speed limitations for your rig.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
#152311 05/04/2007 9:25 AM
I guess you're right about the mileage. I'm just gonna take all the money I can pull together and stop at every town on the way for gas.
Hevyhauler;
You're probably right about 60 mph. No big deal,I'll just set the road speed at whatever makes the engine happy.
I plan to take my '45 Mack for a short test run on the highway (30 miles or so) to see how it's gonna handle the trip. I just talked to a friend up in Elko who offered to bring his tractor trailer down and haul my trucks back for me,so if the Mack passes the road test I'll go ahead and drive it back towing the '62 one ton,but if it fails(not enough power to maintain high gear,too roadwild,etc.)I'll just have the Mack and the GMC hauled and drive my one ton.
OldSub;
The drive from Reno to Elko's mostly relatively flat ground with a total climb from about 3,500 ft. to 5,100 ft. and 3 passes to go over. Nothing really extreme.
BTW-we got the boom finished today,I tested it by swinging it out to the right and picking the rear of Dutch's Ford Ranger up off the ground a couple of feet. (He wasn't very amused...)I'm sure it'll be strong enough.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'84 Bronco II
'78 Dodge W-200
#152312 05/04/2007 8:02 PM
do you have any pictures of the boom on the mack
Now boltless but looking
1951 F-1 350/350
1965 Mustang 355 glide
1971 F-100 401 fe it hates me
1972 Maverick 302 c4
#152313 05/10/2007 9:09 PM
Come on guys...... It's NOt miles-per-gallon..... With old trucks... (especially BIG trucks)... You need to remember one thing.... Gallons-per mile..
Michael
\'48 chev 2-ton boom truck (Boomer)
'49 Chev 2-ton flat bed
'65 Chev 35ft school bus
'88 GMC 6500
'72 Superior 26ft class "A" coach
'50 Farmall "M"
'71 MGB GT
'68 Austin-Healey Sprite
'65 Austin-Healey Sprite
and various other odd British cars
and lots of old radios.....
Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
#152314 05/10/2007 10:46 PM
V
V Offline
Really...what does a 2 ton with a 261 get for MPG?
#152315 05/11/2007 2:35 AM
Quote
Michael
No, no, no... Its SMILES per mile!
#152316 05/11/2007 3:24 AM
I used to drive a 60 school bus that was rated at 2 tons. Had 4speed trans, single speed rear axle. It would run 60 empty fairly easily, but only got about 6 mpg on the road. It had the 261 6.
#152317 05/11/2007 4:22 AM
V
V Offline
Thanks!!!
#152318 05/11/2007 7:56 PM
Sounds like a school buss rear axle may have the gears that some of the guys are looking for.
user
#152319 05/11/2007 8:53 PM
It would run down the road fairly easily at 60. Still had a good bit of power to climb hills. This was in a 1960 Viking chasis with a 48 pass Wayne coach on it. Had the old split rims on it. Always hated working on those.
#152320 05/11/2007 9:27 PM
V
V Offline
I've had it to 45 MPH but it had bad brakes then. I'll give it a try once I get it all back together again with the new brakes... I'll let you know.
