3 members (JW51, Peggy M, 1 invisible), 63 guests, and 1 robot.
Topics128,050
Posts1,055,643
#152250 04/25/2007 11:21 PM
I have a 1933 1.5 ton truck that has a factory looking hole in the top rear of the cab for what I am told is a folding turn and stop signal. There were apparently operated via rope and pulleys inside the cab. By pulling the rope either a "turn" or "stop" arm would raise up or lower. My cab has the pulley hardware still intact, but the signals themselves are missing. Does anyone have any more information or possibly a pattern for this type of signal?
Greg
#152251 04/26/2007 1:05 AM
Your signal was not a Chevrolet option. No turn signals were offered in any of the 1930's trucks. Many outside inventors made lots of different add ons.
34 & 35 trucks are the greatest
#152252 04/26/2007 3:35 AM
They are called semaphore signals if you want to search for some.
#152253 04/27/2007 1:09 AM
Thanks for the help. So far I haven't been able to even find a picture of a truck with signals like these. I'd like to find a good pattern from which to rebuild them.
#152254 04/27/2007 11:19 AM
Look to England. They called them Trafficators, and cars (at least) had them into the 50's. Maybe your truck was once owned by a homesick Limey.
1951 3800
-hotshoe
#152255 04/27/2007 5:04 PM
The semaphores used on trucks were much larger than Trafficators and were mounted to the outside of the body rather than disappearing into slots in the body. Also, the truck type, IIRC, were only on the drivers side and indicated right, left and slowing in the same fashion as an arm signal. They were, in fact, an extension of an arm signal, as an arm signal could not be seen past the load. Some were lighted, others were not, but had reflectors instead.
#152256 04/28/2007 4:47 AM
Thanks Baldy! You are right, thay are mounted on the right side of the cab. Any idea where I could find more information about them?
#152257 04/28/2007 4:52 AM
Where are you with the drivers side being the right side? No idea where useful information can be had other than a Google search.
#152258 05/04/2007 7:00 PM
Oly Offline
Here is a picture of what you are looking for. these are from my 45 GMC COE and 42 GMC 1 1/2 ton.-
turn signals
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#152259 05/04/2007 11:57 PM
Thanks Oly!
The bracket piece looks very similar to mine. Do you know approximately how long the signals are?
#152260 05/08/2007 2:12 AM
the one on my 1939 1.5 ton parts truck is cone shaped about 1ft long and had a light in it some point in its life
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
#152261 05/25/2007 12:09 AM
I think I'll try and look around some swap meets for one. I haven't had any luck finding information online. Thanks for all the help so far.
#152262 05/25/2007 4:55 AM
Ask around at the NTHS or the ATHS these guys should be of some help.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#152263 06/03/2007 10:56 PM
I believe I have what you are talking about on my 46 Chevy COE. Mine is a little faded and has reflectors but the cable and all the hardware is intact and it works. Let me see if I can get a good picture of it posted.
#152264 06/04/2007 3:22 AM
Here's a shot in the dark. If you can find a patent number you can look it up at the US Patent office. Often times the diagrams are able to be viewed and downloaded.
Now I remember, I couldn't idenitify my carb so I ran the patent numbers and got some illustrations for it.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
#152265 06/04/2007 2:59 PM
Here is the links to a couple of pictures of my truck with the folding turn signal.
http://rides.webshots.com/photo/2992325860061479077JujPMx
http://rides.webshots.com/photo/2111939290061479077MfouQx
#152266 06/08/2007 12:11 AM
I checked my folding signal and found it still had the Mfg. label on if interested send me an email and I will send the info back.
