2 members (dt235sd, Peggy M), 76 guests, and 2 robots.
Topics128,130
Posts1,056,713
Members48,454
#151011 02/20/2007 5:27 PM
Ok, I'm about ready to delve into my truck. I really need some sort of a manual to help out. Everything I have seen is for pickups. Was there a manual made for the big trucks? Second, I want to switch over to a "modern" coil. How do you get the top wire OFF of the coil and which wires go where on the new coil? I also need a wire diagram! Thanks!
#151012 02/20/2007 5:44 PM
Hi Dachsund!
You should be able to find a shop manual from most of the shop's that sell parts for old vehicles. I have a shop manual--1942-1946--that includes the bigger trucks. You can also get a 'specification' booklet from the Vintage dept at GM. (sorry I haven't got any contact info for the US but I'm sure other's on here will know)
That's a good looking truck you have. Sort of what mine looked like when I first got it.
http://www.geocities.com/jarge46/46_Chev.html
Good luck with the project and keep us all updated.
Cheers, George
#151013 02/20/2007 5:58 PM
Heres where you can look at the manual. This manual has the wiring diagrams in it. Check the Links section at the top for suppliers to get manuals and such.
http://chevy.tocmp.com/1942_47shop/index.htm
The coil wires should be held on with 2 nuts and the plug wire should just pull off. The powered wire goes to the + side of the coil and the - side goes to the distributor.
Wow, 100$ for her, good deal!
Jeff
My 1953 Chevrolet
1947.1 Gallery
#151014 02/20/2007 6:08 PM
The coil in this is the older style coil where the distributor cap wire comes out of the bottom of the coil. The top wire has a funky cap on it that won't come off! The wire under this "cap" goes back to the dash.
#151015 02/21/2007 1:41 AM
The wire under the funky cap is your hot or positive wire from the ignition
1949 Chevy 6400
1931 Chevy Firetruck
#151016 02/24/2007 3:05 AM
You need to refer to your shop manual on exactly how to release the locking tab under the cap. The coil has to be unbolted from the block so you can twist it (after releasing the lock tab)about a 32nd of a turn which releases it allowing you to get at the wire. This electro-lock set-up was designed as a safety to prevent someone from "hot wiring" the truck.
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
#151017 02/24/2007 1:26 PM
I had 1 with that set up. didn't realize it was a theft deterent
