8 members (JoergK., MickeyP, EchoBravoSierra, FAST55, Forty9, Joe H, 55shaker, 1 invisible), 43 guests, and 4 robots.
Topics128,175
Posts1,057,118
Members48,463
#1508444 07/09/2023 2:53 AM
After retiming the engine, i noticed a new "rattle". Seems like it's coming from about the middle, around cylinders 3&4. Sounds like a loose nut is moving around somehow. i've removed the valve cover and nothing obvious. The engine runs fine and sounds fine other than the rattle. I've removed the pushrod cover, nothing to report. it's definitely inside the engine. any ideas?
thanks a bunch,
Many Blessings,
Oldtruckspapa
Blessings,
Oldtruckspapa
My 62 C10 has a 1960 235 in it . It runs good and has good oil pressure. It also ticks and rattles. Runs better than it should 👍
1962 C10 with a 235 6cyl -- all of the drive train seems to be original.
Some of this story is in the Side Lot
Some people like a new truck. I liked the old ones.
Have you checked the lash on the valves?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
If you're convinced the valves are properly adjusted, removing oil pan may be your best option to find a loose nut. That's not a terrible thing, just kinda messy. thumbs_up
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
thanks very much everyone. really appreciate your input!!
Blessings,
Oldtruckspapa
Valve adjustment first. But also check for exhaust leaks. All the sheet metal makes exhaust leaks sound like knocks and ticks.
1951 3100
I have a '61 model 235 that has a similar sound, like a nut or something is clanking around in the oil pan intermittently . The engine runs fine so I wonder if it is just exhaust expansion,
I invest my money in precious metals, mostly rust!
Curious why the "re-timing" ? If you put the timing back to where it was before, does the noise go away or is it just coincidence that the noise occured after retiming?
Ron - - Dusty53
1954 Chevy 3604
