2 members (Nick in Manitou, 1 invisible), 60 guests, and 1 robot.
Topics128,049
Posts1,055,679
#148267 09/13/2006 3:23 AM
Junior Member
Junior Member
I've got a spare windshield for my 68 c50 and would like to replace the original fogged one. I realize there's a hard way and an easy way to do stuff. What's the easy way? I imagine you need new molding. Where do you get it?
#148268 09/13/2006 3:36 AM
Order one for a pick-up, they should be the same. After you get it, you'll need some light duty rope, some silicone spray and a few helping hands. Install the seal to the glass, insert the rope into the seal in the area that goes into the wind frame and set it in place. Try to get as much of the lower part of the seal started over to window frame by hand. Now have several people push in and down on the glass while you pull the rope around the w/sheild. The rope pulls the seal over the edge of the frame without marring it up. Spray the silicone liberally until the seal is installed. After the rope is out, push and shove the glass around until you're satisfied with it's fit.
Easy as that,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#148269 09/21/2006 10:08 AM
Scott;
Does that same method apply to the rear glass on my '57 big window?
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#148270 09/21/2006 2:07 PM
One thing on the 67-72's, put the top in first-the sharp corners are hard to get in. I also usually soak the rubber in hot soapy water or lay it out in the sun on a warm day. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#148271 09/21/2006 11:30 PM
48 big trucks method worked on the back glass of a 81 chevy pick up
