5 members (cmayna, Goach2, 2-Ton, Wally / Montana, jmoore), 66 guests, and 4 robots.
Topics128,203
Posts1,057,412
Members48,471
#147243 06/24/2006 12:29 PM
After working for the past 2 yaers, my truck (1941 Chevy G506 1 1/2 ton tipper) is is almost complete. The truck has the orginal hoist (Hercules) and the original bed. Everything has been rebuilt with NOS or rebuilt orginal parts.. The engine has been upgraded to a 1955 235. The cab came from a donor truck and the firewall is NOS. All sheetmtal forward of the firewall is military specific as are the instruments (gauges). This site has been very helpful in the restoration. So I am now in the process of finising the truck's new home in its brand new garage.
Check out the pictures at
[email protected]
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
lets try this one more time............
http://[email protected]
Anonymous
Unregistered
Anonymous
Unregistered
still can't see your pics,I'll look a little later.
42chevy - that's a mail address, not a website - do you have your pics uploaded to a host someplace? if so you need to go to the page, copy the full address from your browser address bar and paste that here for a link
if you don't have them already on the net, then pull out the ol Glove Box book and check the picture posting page cuz we can always use a new picture fix here! grin
lets try this again.........
http://mysite.verizon.net/jbgott/
that works! lookin good, and a pretty classy home for it as well grin
Anonymous
Unregistered
Anonymous
Unregistered
that's cool,do you collect alot of military stuff?
Big Bolt Shop Curmudgeon
That is a very good looking military truck.
Any more pictures?
Put that to work (hauling air, maybe (after all, ya wouldn't want to mess it up!) and that would be a nice addition to upcoming "Big Bolts doing Real Work" calendar.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
To answer a few questions, I do not collect any other military stuff. I will add a few pics. I used it to haul dirt when we were putting in the new propane tank (at the time I did not have the cab on). Also I just added some pics to show why I did not make it to the ATHS convention in Baltimore, after changing my second flat tire on the Baltimore Beltway, I trialered it home. Also have some shots of her in ACTION hauling dirt.
what was the cause of your flats on the belt way. punctures or blowouts due to dryrot ?
After much discussion, it was determined that that I did not have enough air pressure. I was running 35 psi, As was specified on the tire (6 ply 11.00x18 tubeless "Gamma Goat", the original DUKW tires were 12 ply. Tires, tubes, flats were all new.I am now running 50 psi. Looks like the tube was chaffing against the tire, because of the low pressure. These tires are a high flotation type. I have the orginal 7.50 x 20 wheels/tires, but I like the look of the combat wheels smile
I really like your truck. It is really cool. I have one question however. Wouldn't it have had dual rear wheels as a dump truck? I've never seen a single tire military dump.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
thanks for the reply, wondered when you had two of them go out
Yes the truck originally came with dual rear tires, However, field mods (mostly done by the French) placed DUKW tires on these trucks because they were a high flotation tire, However you could run duals on the front axle if you were in mud or sand
