9 members (Hotrod Lincoln, sron48, FAST55, Uncles51, gswbbc, Hanks custodian, 32Fordpuchoptop, Joe W, 1 invisible),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 14 Junior Member | | Junior Member Joined: Jan 2006 Posts: 14 | I have a 1 1/2T and am wondering if a 10 x 20 tire will work or will it rub on the springs. There is an auction coming up and if they will work I'm gunna buy'm?
naylor 36 Chevy 2 dr sedan 48 dumper 1 1/2 64 Chevelle 2 dr HT 51 F1 pick-up 52 F1 pick-up several stationary motors many old tractors
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | 10:00x20 tires require 7.5x20 rim. You don't state the year of your truck but a 1-1/2 ton would likely be 8:25x20 with 6.5x20 rim or even a 7:50x20 on a 6". 9:00 tires require a 7" rim. If the rims you have will fit the tires you want then I can't imagine that the tires would rub the springs as you would expect to see on a pickup or car. There is a lot more clearance on a cab & chassis. But whatever 10:00 is too big for any 1-1/2 ton truck. Your GVW will determine what you need or what came standard on it. What year is it? | | | | | Joined: Jan 2006 Posts: 14 Junior Member | | Junior Member Joined: Jan 2006 Posts: 14 | I have 6.5 rims with 8.25 tires ann right now the tire is about 1 inch away from the spring. Th e truck is a 48.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | OK. Better leave it alone. | | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | I tried to fit a 9.00x20 on my 53 Reo and they would hit the spring It is supose to 7.50x20. The tires were free so I thought I would give it a try. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Hey Mike, make sure all of your wheels are 6.5 inches wide. I've got a truck that's got mismatched wheels on it. 7.50's on the front and 8.25's on the rear. In my opinion, 8.25's are as big as you'll want to go on a 1 1/2 ton. If we could buy the 7.50's for the right money, I would but them, but you can't, Scott | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I've been kinda fond of the 8.25's-thats what I put on my ol' 51 Ford F-5,and they fit fine. They're right-that's about as big as you can go. Another thing you want to watch is how close to each other they get. You see a lot of the one tons running too big tires on the back,and the sidewalls chafe against each other,building heat,especially if you load it down. Not as much of a problem on the bigger trucks,but if you want to try 9.00 or 10.00 tires,you'll want to keep this in mind. Speed | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I tried to find 7.50's also in a radial without luck. I'm running the 8.25's all around but it does rub the frame in the front on a stop to stop turn. I'll just make sure I don't get caught in a tight spot.
I'd like the 7.50s too but for $175 each, I'm going with the cheap and becareful how sharp I turn. | | | | | Joined: Jan 2006 Posts: 14 Junior Member | | Junior Member Joined: Jan 2006 Posts: 14 | Tuckers Tire Company out of Tennesse has new tires. You can get 4 tires 8.25x20 for $340 but it costs you $100 to ship them. They have many other size tires also. He sells on EBAY
| | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | He has 4 for 340 + $100 shipping or 6 for $570 + 150 shipping That doesn't make much sense to me. $110 a piece if you buy 4 $120 a piece if you buy 6 He also has 7.50x20s for $85each + $25 shipping Tucker Tire Ebay Web Store | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Originally posted by 48 dumper: I have a 1 1/2T and am wondering if a 10 x 20 tire will work or will it rub on the springs. There is an auction coming up and if they will work I'm gunna buy'm?
I presume you'll be at the Dodge dealership auction this Saturday? As will I, see you there, Scott | | |
