10 members (NJC, KCMongo, JW51, MickeyP, HandyAndy, 32Fordpuchoptop, Steelonsteel, Hotrod Lincoln, 2 invisible), 135 guests, and 3 robots.
Topics128,042
Posts1,055,505
Members48,424
#146211 03/22/2006 7:52 PM
Junior Member
Junior Member
I have a 1 1/2T and am wondering if a 10 x 20 tire will work or will it rub on the springs. There is an auction coming up and if they will work I'm gunna buy'm?
naylor
36 Chevy 2 dr sedan
48 dumper 1 1/2
64 Chevelle 2 dr HT
51 F1 pick-up
52 F1 pick-up
several stationary motors
many old tractors
#146212 03/22/2006 8:23 PM
10:00x20 tires require 7.5x20 rim. You don't state the year of your truck but a 1-1/2 ton would likely be 8:25x20 with 6.5x20 rim or even a 7:50x20 on a 6". 9:00 tires require a 7" rim. If the rims you have will fit the tires you want then I can't imagine that the tires would rub the springs as you would expect to see on a pickup or car. There is a lot more clearance on a cab & chassis. But whatever 10:00 is too big for any 1-1/2 ton truck. Your GVW will determine what you need or what came standard on it. What year is it?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#146213 03/22/2006 10:06 PM
Junior Member
Junior Member
I have 6.5 rims with 8.25 tires ann right now the tire is about 1 inch away from the spring. Th e truck is a 48.
naylor
36 Chevy 2 dr sedan
48 dumper 1 1/2
64 Chevelle 2 dr HT
51 F1 pick-up
52 F1 pick-up
many old tractors
#146214 03/22/2006 11:00 PM
OK. Better leave it alone.
Dave
#146215 03/23/2006 12:33 AM
I tried to fit a 9.00x20 on my 53 Reo and they would hit the spring It is supose to 7.50x20. The tires were free so I thought I would give it a try.
#146216 03/23/2006 3:36 AM
Hey Mike, make sure all of your wheels are 6.5 inches wide. I've got a truck that's got mismatched wheels on it. 7.50's on the front and 8.25's on the rear. In my opinion, 8.25's are as big as you'll want to go on a 1 1/2 ton. If we could buy the 7.50's for the right money, I would but them, but you can't,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#146217 03/23/2006 8:13 AM
I've been kinda fond of the 8.25's-thats what I put on my ol' 51 Ford F-5,and they fit fine. They're right-that's about as big as you can go. Another thing you want to watch is how close to each other they get. You see a lot of the one tons running too big tires on the back,and the sidewalls chafe against each other,building heat,especially if you load it down. Not as much of a problem on the bigger trucks,but if you want to try 9.00 or 10.00 tires,you'll want to keep this in mind.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#146218 03/23/2006 12:18 PM
V
V Offline
I tried to find 7.50's also in a radial without luck. I'm running the 8.25's all around but it does rub the frame in the front on a stop to stop turn. I'll just make sure I don't get caught in a tight spot.
I'd like the 7.50s too but for $175 each, I'm going with the cheap and becareful how sharp I turn.
#146219 03/23/2006 9:14 PM
Junior Member
Junior Member
Tuckers Tire Company out of Tennesse has new tires. You can get 4 tires 8.25x20 for $340 but it costs you $100 to ship them. They have many other size tires also. He sells on EBAY
naylor
36 Chevy 2 dr sedan
48 dumper 1 1/2
64 Chevelle 2 dr HT
51 F1 pick-up
52 F1 pick-up
many old tractors
#146220 03/24/2006 1:37 AM
He has 4 for 340 + $100 shipping or 6 for $570 + 150 shipping
That doesn't make much sense to me.
$110 a piece if you buy 4
$120 a piece if you buy 6
He also has 7.50x20s for $85each + $25 shipping
Tucker Tire Ebay Web Store
#146221 03/24/2006 2:34 AM
Quote
I presume you'll be at the Dodge dealership auction this Saturday? As will I, see you there,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
